Brand New Onan QG 5500 not turning
zoostory
Hey guys and gals,
Total RV newbie here. Living fulltime in a Thor Windsport 34R my wife and I purchased about 6mo ago.
I just tried to run our generator, just to break it in a bit, and it wouldn't turn over. I popped it open and primed the fuel, still nothing.
I then got worried cause we were still connected to shoreline power, so I unplugged the shorline, and now the lights wont even come on on the generator switch and the on switch does nothing???
I'm struggling to figure out what this could be? My wife said it worked when we first got the RV. I was out of town, and we had it in storage for a few months, if that means anything?
Our tank is just about 1/4 full.
Any thoughts are much appreciated!
20 REPLIES 20
zoostory
dougrainer wrote:
seriously people, does not this paragraph camouflaged as a sentence NOT GIVE ENOUGH CLUES?
I am having fun following this...:)
AND, the OP has never clarified WHAT he means. Does the Genset TURN OVER at all? THAT would help narrow it down. But, he has NEVER answered this question. Doug
Genset was turning over for a while. Now it's not. Thanks for all the help guys, and glad I can entertain. I've called a professional to come take a look as this is out of my scope and I don't want to mess around with any electrical without proper knowledge!
dougrainer
MEXICOWANDERER
  • Battery power from battery bank is being interrupted when shorepower is disconnected but coach lights aren't?
  • Why isn't the generator power cable transmitting power while unplugged?
  • You are omitting asking the OP to do vital successive troubleshooting
  • Having the generator power light lit only when shorepower is disconnected is a clue.
MEXICOWANDERER
2oldman
zoostory wrote:
..brand new batteries that we installed recently. How can I check to see if they are dead or not? Also, when I unplug the shoreline, I still have power to my wired lights, doesn't that mean the batteries are not dead?
voltmeter. Sounds like they're ok.
wopachop
So its either a loose battery connection or maybe by some fluke the brand new genny is low on oil?
dougrainer
One thing. Even tho the coach batteries are somewhat new. SOME RV's, if the battery disconnect is turned OFF, that disconnects the Coach batteries from the Coach charging system and the coach batteries will go dead after a few weeks. On this type connection, the battery disconnect ON light, if you have one, will be ON, because the ON light receives its signal from the COACH side of the Disconnect relay. This scenario only affects RV's with POWER CONVERTERS. If you have a INVERTER/CHARGER, the batteries are connected direct to the Inverter/Charger. Doug
dougrainer
Fuel problem WILL NOT cause lack of the Genset turning over. Only lack of sufficient battery power or a bad starter. You will only really hear a clicking sound at the Genset when pushing the prime button and an occasional genset fuel pump burp. Doug
Think of it this way. Your Automobile is out of Gas or the Fuel Pump is bad. The engine will turn over until you either burn out the starter or your battery goes dead. Same with a genset.
MEXICOWANDERER
You have separate and distinct problems and both point at the coach batteries, You need to troubleshoot this, not guess at it.
Defective circuit from RV batteries to Generator starter will cause no crank. Converter power alone stands no chance of making a noise never mind cranking over the generator,
First step in the easiest way of troubleshooting
Jump start coach batteries with jumper cables from your car. Does the generator now crank?
Try it
zoostory
wopachop wrote:
Sounds like its the low fuel tank.
Does anyone know if the genny will prime even with low fuel on that type of setup?
Because hitting the prime button and listening for noise would help us know if his genny is getting 12v.
Hmmm, when I hit the prime button, I don't hear anything, a red light does come on. I am doing this from the chassis. The engine has gone from sounding like its about to turn over, from the power button doing absolutely nothing at all, with or without shoreline. So I'm guessing this is a fuel tank thing? We're just at 1/4.
zoostory
pianotuna wrote:
will the motorhome start?
Yep!
wopachop
pianotuna
Nomad III
Nomad III
Regards, Don
gbopp
zoostory wrote:
Hmmm... these are brand new batteries that we installed recently. How can I check to see if they are dead or not? Also, when I unplug the shoreline, I still have power to my wired lights, doesn't that mean the batteries are not dead?
Make sure the battery terminals are clean and tight. A little corrosion can cause problems.
