Atwood gas furnace
Barry_J
We have a Brand new park model with an Atwood gas furnace
Tonight before we left the campground I tried to turn on the furnace and the fan(blower) would turn on and off over and over, but would not ignite. I did not hear the usual clicking as I did before. The fan after turning on and off a few times would trip the GFI circuit. I reset the circuit and tried again but same thing happened.
When I look at the circuit board in the furnace, it has a red light that stays on.
What could be the problem
Thank you
Barry
5 REPLIES 5
Old-Biscuit
BFL13 wrote:
OP says it is in a park model. Park model furnaces have gas with AC and DC voltages.
https://pantherrvproducts.com/dometic-atwood-31095-afl-furnace-ac-to-dc-transformer/
That is why MODEL Number is needed.
Atwood AC Models use 24VDC as control circuit to trigger the 120VAC circuits
Would imagine it is a 8900 Series
Issue could be with the AC/DC Transformer OR the Timed Delay Relay
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Old-Biscuit
Model of Furnace???
Fan on/off over and over suggests issue with 'Blower' circuit on furnace circuit board
OR issue with thermostat
DC Voltage is at furnace waiting for dc signal from thermostat ....when received the FAN starts/purges and makes up sail switch to allow DC to 'Power circuit'
Model of furnace??
jdc1
Is the propane on? Did you purge the lines?
Ed_Gee
You should seek and download the user manual for whatever furnace model you have. They all contain very helpful troubleshooting procedures. Is this an RV or a house you have? I am curious what your GFI has to do with the furnace. Every RV furnace I have seen runs totally on 12VDC and has nothing to do with 120VAC......
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
