Champion 2000 watt on sale
hbski
If anyone is looking for the Champion 2000W inverter generators, Home Depot has a pair with the parallel kit on the special buy of the day for $800
'06 Dodge 3500 4x4 QC LB DRW
Ride-Rites, Hellwig, Torklift Tiedowns, Fast Guns, Superhitch
'07 Okanagan 117DBL
29 REPLIES 29
MrWizard
Moderator
Moderator
There is no sensor to stop it running
But road heat and air flow may cause an over heat condition
Or
They might be enough air flow so everything is ok
We have no way of knowing that you will learn that when you try it
The other thing will be keep it full of gas, if it gets low while driving it might shut off turning some corner or going uphill
Trying to re start a hot a/C with a hot generator does not work very well
Often causing instant overload
And you have to wait for both to cool down before you can use the a/C again
Just things to consider
I can explain it to you.
1997 F53 Bounder 36s
goreds2
I have been wanting to pull the trigger on a Champion 2000 or another brand. Will the Champion continue to run the Air Conditioner while in transit?
Asking because my Dash AC has not worked well in the past couple years and my plan is to place the Champion 2000 on my rear cargo basket and drive around with it turned on.
I am not sure if the Champion 2000 has a sensor to stop the unit if it moves etc. Thanks,
Note that My 89 Xplorer has the original 7100 BTU air conditioner.
See Picture In My Profile
I have a 1989 Dodge XPLORER RV Class B - Purchased 10/15/10 IN CASH
Fiance' purchased a Class C 2002 Dynamax Carri-go on 5/1/15 IN CASH
We've got the best of both worlds
Rygar
I saw them Saturday on homedepot.com. It was 1 2pk of Champion 2000w inverters plus the parallel connector for $799. Great deal.
2011 Montana 3455SA
2013 Ford F350 4x4 Crew Cab King Ranch SRW
Gary & Jane Retired Toy Store owners
2 Sheltie Furkids Cammie & Stormy
2oldman
bucky wrote:
I went to the site Sat and no mention of the sale.
They're a grand today. Still a heck of a buy.
bucky
I went to the site Sat and no mention of the sale. Both the link and independently. Maybe just regional?
Puma 30RKSS
Lantley
Did anyone actually purchase at the sale price?
2oldman
They're both $999 today.
Lantley
When trying to purchase online. It bring up 799.00 each.
I'm curious is Home Depot honoring this deal? Has anyone actually purchased 2 for $800.00 total?
Rygar
Also, the Costco price for 2 2000w plus the parallel cable is $1276. cdn.
2011 Montana 3455SA
Rygar
Wow, that's an awesome price. Unfortunately, Home Depot in Canada doesn't carry Champion. However, Costco does. So, would two 2000w inverters running in parallel be better than the Champion 3400w which claims to be able to run a 15000btu a/c? I'm also thinking lifting 2 48lb inverters is better that lifting 1 110lber. I guess I'm wondering if it's output is 4000w or is there a reduction in wattage running it parallel?
2011 Montana 3455SA
road-runner
Edd505 wrote:
Wish I hadn't already bought the 3100 I'd jump on this.
And if I didn't already have an eu2000i I'd probably be jumping on it, too.
2009 Fleetwood Icon
rhagfo
hbski wrote:
2oldman wrote:
hbski wrote:
The Home Depot deal is the 2 generators plus the parallel cord
It says "each" on the price. Confusing.
title says generators (plural) and the description says it includes 2.....and they have the single for $463.
Text of the kit;
About half way down state TWO generators and 30 amp parallel cable!
Quiet and lightweight, perfect for taking on the road
Can power lights, TV, fridge and more
Great solution for emergency situations
Model73536KInternet/Catalog:300809153
The Champion Power Equipment 73536i 2000-Watt Stackable Portable Inverter Generator is a quiet and lightweight addition to your RV, your next camping trip or a weekend of tailgating. It is perfect for powering items around the RV or campsite like lights, TV, small refrigerator, slow cooker or coffee maker. This unit features two 2000-Watt Stackable Portable Inverter Generators as well as a 30 Amp RV Ready Parallel Kit for Linking (2) Stackable Inverter Generators. This combo makes a great solution during an emergency to power a few essential items you need in a power outage lights, microwave, fan, TV, modem/router, cell phone charger, etc. (Note: this unit is not recommended for emergency home backup for powering air conditioners, stoves, furnaces or sump pumps.) The inverter produces 2000 starting watts and 1700 running watts. The unit features a patented, space-saving stackable design. It is also Parallel Ready and has the ability to connect with another Champion 2000-Watt Inverter for 30A of power. The included Champion 2000-Watt Parallel Kit is designed to integrate seamlessly between two stacked inverters and comes travel-ready with standard 30 Amp RV outlet with enough power to start and run a 15,000 BTU RV air conditioner. The inverter produces Clean Power (<3% THD) making it suitable for use with sensitive electronics such as computers, flat screen TVs and more.
Includes two 2,000-Watt stackable portable inverter generators and a 30A RV ready parallel kit for linking
Quiet, lightweight and stackable operates at 53 dBA and weighs less than 50 lb. with space saving stackable design, great for RVs, campsites, cabins and more
2000 starting Watt and 1700 running Watt, with up to 9.5 hours run time on a full tank of gas
Powered by a reliable 80cc champion engine and parallel ready, connect with another champion inverter for increased power
Outlets - two 120-Volt 20A household and 12-Volt DC outlets with clean power, clean electricity for powering sensitive electronics
Champion support - 3 year limited warranty with free lifetime technical support
Edd505
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
2oldman
well that is a hell of a deal.
