โOct-12-2019 08:26 AM
โOct-12-2019 01:40 PM
โOct-12-2019 12:26 PM
โOct-12-2019 12:25 PM
โOct-12-2019 11:08 AM
DutchmenSport wrote:
You did not say what brand/model/year your camper is, nor what kind of solar system you have. However, YouTube has everything.
A very simple search on YouTube.com for "electrical systems in RVs" returned this: Click here
Refine the search in YouTube use the hourglass by putting in your make-model-year of RV, pertinent info regarding anything you may know about the electric system, solar panels, anything, and you'll get more videos than you can imagine that will walk you through absolutely everything. Weed past the obvious not related videos, and some you watch may not have relevance at all. But, YouTube is your friend.
โOct-12-2019 10:30 AM
BFL13 wrote:
Seems you were running on inverter for your 120v needs and that ran the batteries down enough so the inverter shut down. There would still be enough battery to run the usual 12v things -lights, fans, etc.
When off-grid, you need to "power manage" what the inverter is running so the batteries can keep up. Put the fridge on propane, WH on propane, limit use of 120v appliances. When not watching it, unplug the TV set, don't just turn it "off", which leaves it on. All kinds of tricks to get by longer before you need to recharge the batteries.
At some stage you do need to recharge them, no big deal, but best if they can be done during the day instead of at 3am! ๐
โOct-12-2019 08:41 AM
โOct-12-2019 08:39 AM
