Control Panel Lights Flashing
Campnfuls
I have a 2007 TropiCal (National RV). I had a couple of 6-volt house batteries on my MH go bad recently. The lights on my control panel inside my coach were flashing wildly throughout the entire panel. I placed all new batteries in yesterday thinking this would stop the problem. It didn't. Any suggestions before I take it in for servicing?
I want to leave this earth quietly in my sleep like my grandfather and not like the hysterical, screaming passengers riding in granddad's RV just before the big crash.:E
2 REPLIES 2
techie122000
Just had that happen to me yesterday. My 2005 Safari Cheetah had been unplugged for almost a week while at the garage for oil guage repairs. I left the inverter on (next time turn it off) so the house batteries were dead when I picked it up. Got home, plugged in and all the lights for the inverter panel were irratically flashing. Only way I could stop them was to go to the inverter and unplug the connection labelled "to remote". After doing that it started behaving properly.
MrWizard
Moderator
Moderator
Removed control panel from where it's mounted
Unplug connectors
Wait a few minutes then reconnect them
If that doesn't fix the problem you m might need to replace the panel
I can explain it to you.
1997 F53 Bounder 36s
