Converter/Charger amps and wire size
McKenziek
The current setup is a WFCO 55amp converter roughly 20 feet away from 2 12V batteries. I'm installing 4 Trojan T105's. I'd like to upgrade the charger to charge the batteries quicker and if so which brand and amps? I had good luck with the Intellipower 9280 years ago. Are they still tops? Lastly, given the amperage of the charger and the distance to the batteries what size wire?
2005 Monaco Diplomat
5 REPLIES 5
mena661
You're running 20 feet of wire? I would move the converter close to the batteries and run the 120V line back to the breaker panel or receptacle. 120V isn't as sensitive to voltage drop like 12V is. It's also a lot cheaper wire (120V is). You CAN run the 12V wire 20 ft but you'll never get all 80 amps and likely you'll have to manually trigger the PD to go into boost mode.
renoman69
I use an Iota DLS75 with IQ4 with my 4 6v Trojans and it has worked flawlessly for over a year now and I have not had the problem low water in the batts as other have on here using other converters.
2009 Jayco Eagle Superlite 25.5RKS
2008 Silverado 2500HD Z71 4x4 Duramax/Allison
Reese 15K slider
Honda EU2000I,
270 watts of Kyocera solar
Blue Sky 3024i MPPT controller
450 AHs of Trojan power
Iota DLS-75/IQ4 converter
mbopp
I put in an additional deck mounted converter in my pass-through. From there it's only a 3' run to the batteries. AC power was tapped off a bedroom outlet and run to a switched outlet in the pass through.
2019 F250 XLT Supercab
Just DW & me......
VintageRacer
The 9280 is what I would choose. I would pull #3 or #4 wire, depending on type, but #4 is probably more than adequate for only 12 feet from a voltage drop point of view. That charger will rarely operate at 80 amps, more like 20 or 30 most of the time. http://www.armstrongssupply.com/wire_chart.htm
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
time2roll
9280 will serve you well. If pulling wire I would go #4.
