Converter fan isn't running
Varin
I was getting annoyed by how loud the cooling fan for my converter was so I switched it out with another fan. Problem is, it didn't work, and switching back to the older fan doesn't work either. Gotta stop trying to fix things...
I'm definitely putting enough of a load on it to trip it, and the converter is working fine otherwise. When I measured the voltage the fan is receiving, I only got about 0.5v but I'm not sure if that's just because it isn't tripping as opposed to it just not working.
I'd really rather not have to replace the entire converter just because a $4 part went wrong, does anyone have any ideas of what went happened/what I could do to fix it?
The converter is a WFCO, Model WF-8955PEC.
Thanks!
8 REPLIES 8
beemerphile1
Low budget or temporary fix would be to supply manually switched power source to fan. You will need to turn it off and on as needed.
Plugged into shore power = switch on.
Operating on battery power = switch off.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
cyntdon2010
best converter.com
ask for randy..
I purchased the power max
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
MEXICOWANDERER
Just for drill I will answer the OP's question...
Fan driver transistor gets hotter than snot if load exceeds @ 2 watts. If you stuck, say, a .5 amp 6 watt fan on it, its going to have SDS (sudden death syndrome).
If they priced Wiffies at $10.00, they would not be worth the money. They make better than nothing bench-top power supply but that's really reaching. my $22.00 cheapOwatts make for far-better bench power-supplies.
SidecarFlip
Buck and a half gets you a PD every day.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
garyemunson
The WFCOs would turn the fan on when it got hot. I suspect the circuit that does that has failed. I suspect that is a function of the main control board and not worth fixing. New converter time.
Germania
Replaced my 13 year old WFCO with a new PD,havn't heard the fan run yet.Newer technologies don't produce the heat the older ones did.
time2roll
WFCO is not that good anyway.
Replace with PD, IOTA, or PowerMax.
Not sure who has the quietest fan....
When I switched to LED lights I never really heard the fan again.
SidecarFlip
How old is it?
