Converter issue
Stude55Dog
Have fifth wheel on 50 amp service. Am now on 3rd converter. Yesterday we had fake fireplace on and the breaker on box tripped. Turned fireplace off, turned breaker back on and smelled smoke, went outside and the converter was emitting heavy smoke. Unplugged, went got another converter, make sure fireplace was unplugged, installed converter, turned breaker back on and it smoked that converter immediately. Not sure what to do next as it is weekend, cant reach mfg. for advise. Need to figure out as we live in trailer. Would appreciate any guidance or suggestions. Thanks
24 REPLIES 24
enblethen
Large black and red should come from the batteries.
Yes, could be in shore power cord.
How does things work off genset? If working, other then converter, problem would be between transfer switch and pedestal end of shore power cord.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Stude55Dog
Breaker in rv tripped. It is a 15amp breaker. I put a progressive surge protector on 50amp plug from power pole and it reads all good. Where does red and black cables that go to converter come from in rv? Could 50amp cord be a problem. Will check voltage at converter in am, even thou it is not plugged in but still has black and red cables connected if that possible. Once again thanks for all the input and thoughts, suggestions. Will report back as we get answers, solutions
enblethen
The fireplace maybe on one leg of the shore power and the converter on the other. When the OP turned on the fireplace it placed the converter and fireplace in series do to an open neutral. Thus 240 volts through them.
Bud
USAF Retired
Pace Arrow
pnichols
:h I'm not sure what a fake fireplace has to do with an RV's converter.
Isn't the fireplace powered by 120V AC from the shore power?
And doesn't the converter merely make 12V DC from the 120V AC shore power so as to power the various 12V DC items in the RV ... none of which have anything to do with the fireplace?
2005 E450 Itasca 24V Class C
dougrainer
Lets keep this simple. He has burned out 2 Converters and on his 3rd. IF he had a voltage supply problem(open neutral/loose wires), OTHER appliances(TV/Microwave/Refer 120 side fuses/Fireplace) would also fail. I would suspect bad battery or a miswires(reversed Positive and Neg) from the battery. Now, some are fixated on the Fireplace. That is a 120 appliance and will not contribute to his problem. The Converter is connected and powers the 12 volt DC side of the RV. Just supplying 120 to it will not cause a malfunction. UNLESS there is 12 volt problems on the Output side. Since he is under warranty, he needs to STOP replacing parts and get the unit in to his dealer for a check out, to find the CAUSE of his problem. If he thinks he will get reimbursed for the converters, he is in for a rude shock. NO OEM is going to pay for self help that keeps destroying expensive parts. They may pay for one but not more than the one. Doug
The OP needs to clarify his first post. He stated "Breaker on Box tripped" Turned off and turned Fireplace OFF and turned breaker back on and Converter fried.
WHAT BREAKER ON WHAT BOX? The CG supply breaker to the 50 amp plug for his 50 amp cord? The breaker in HIS RV 120 breaker box?
If the CG breaker, then YES, odds are the CG breaker box/50 amp receptacle has a problem, like a open Neutral(probably BURNT) or shorted wiring which will indeed fry a 120 appliance, like the Converter, BUT, as I stated this scenario will also fry some of the other 120 appliances, not just the Converter
MrWizard
Moderator
Moderator
if your going to quote me
keep it in context
i did mention the need for 12v
there is NO proper reason for an RV absorption fridge to have to have a 'converter' plugged in, even for 120v operation
it does use 12v control circuit, but if the battery is charged
it should work on 120v or LP with a 'converter' unplugged
the way the OP said it, the converter is already unplugged and the fridge only works if the converter is plugged in
that would make the converter in series with the fridge
something is NOT correctly stated or wired !
I can explain it to you.
1997 F53 Bounder 36s
wa8yxm
If the fridge has fans they are 12 volt
TRhe interior light is 12 colt
The seal heater (Controls moisture) is 12 volt
And the DSI ignitiobn systemn and the control system for the fridge is 12 volt.
IN short it will not work at all without 12 volts.
ANd if your batteries are dead/missing/disconnected and the converter is toast there is no 12 volts.
MrWizard
Moderator
Moderator
there is a cross circuit short or back-feed someplace
do you have a 50amp RV plugged into 50amp service with an open neutral or open hot leg
converter is offline
beg borrow or BUY a 30amp or larger battery charger
use an extension cord to the power pedestal, and connect the charger to your battery
set your fridge to LP, at least you will have lights and your fridge will stay working
while you trouble shoot your problems
beemerphile1
Brand and model number of converter would go a long way in an online diagnosis. We aren't standing beside you seeing what you see.
Who installed the fireplace? When was it installed?
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
time2roll
Yes a loose connection in the TS can cause the issue. And I would be checking voltage under load first. Use a hair dryer to load up one side, check voltage on the main breakers in the RV.
Stude55Dog
Fridge runs on propane and elec. Have one house battery. Could bad transfer switch cause this kind of issue? Checking all things being suggested. Thanks to all for help. Will report back as things checked. Thanks again.
time2roll
+1 to check voltage under load. Especially check with an unbalanced load. Look for hot spots in your breaker panel. Possibly install a Progressive Industries EMS to protect you from supply issues.
MrWizard
Moderator
Moderator
Do you have a residential compressor fridge 120v only?
Do you have house batteries?
An l.p. Fridge will run on lp and batteries, no converter or inverter needed
Sounds like you have a combo inverter/charger
And it's being overloaded,
Electric fireplace should Not be on that circuit
enblethen
Are you at the same location or have you moved?
Same location could be shore power pedestal problem.
If this is open neutral problem, other 120 volt items can be effected that will show up now or sometime later. 120 volt water heater element, refer 120 volt element for example.
Bud
USAF Retired
Pace Arrow
