converter testing
ibycus
hey all... I seem to be having an issue with my power panel/converter.. It appears as though all my A/C circuits are fine, however, my battery is dead and none of the D/C things are working..
what's the best way to test to see if the converter has died?
thanks
2013 Silverado 3500 DRW Diesel
2013 Dutchment rubicon 2900
Superglide 4400 (for sale) ๐Ÿ™‚
7 REPLIES 7
Bobbo
With electricity, you follow the flow.
1. be sure you have current TO the converter (if no, breaker/connection)
2. be sure you have current AT the converter input (if no, wire/connection)
3. be sure you have current AT the converter output (if no, converter/fuse/connection)
4. be sure you have current at the battery. (if no, fuse/wire/connection)
When you find the first spot in that list without current, you have drastically narrowed down the list of possibilities, and should know where to look further.
Bobbo and Lin
Fleetwood99
ibycus wrote:
hey guys... thanks for the advice..
so, for reference, the model number of the unit is WF-8955PEC
We had a power surge a couple weeks ago and it literally fried 4 surge strips in our house... I'm hoping I'm wrong, but my fear is that it took out the converter too...
Here's a WF-8955PEC manual that may help you.
One thing you can double check is the AC Breakers. Physically turn each CB OFF then back to ON this will reset any that have been tripped.
Good Luck on your mission.
99 Fleetwood Vision 36Zulu V10 Gas F53 Chassis
Hyd Leveling man/keypad (Powergear)
Electric Slideouts (Powergear) x2
2005' 4020 Fadal 4Axis CNC Mill w/24Datc
Hendy 16x72" WWII Navy Lathe 1800RPM
BFL13
So look for 120 going into the converter for sure. You might have to pull it out to see in back where it is plugged in so you can test that receptacle for 120 (meter or try something else like a portable fan that is known to work). If no 120 there, check the circuit breaker--snap back and forth. You said the other 120 stuff works.
My converter (not a wfco) has a 120v fuse inside on the circuit board where the 120 cord comes in but you have to take the metal box cover off to get at that.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
ibycus
if I'm understanding you guys correctly, there should be fuses on the line side and the load side of the unit, correct? should they all be accessible from the front panel, or do I need pull the unit out in order to find some? All visible fuses appear to not be blown...
beemerphile1
Make sure all fuses and all connections are clean and good, both in the converter and inline between converter and battery. Then test like westend said.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
westend
Measure voltage across the battery terminals. With the converter powered, you should see 13.2 VDC +.
'03 F-250 4x4 CC
BFL13
thanks
Take the wires off the battery, make sure the 30a reverse polarity fuses on the converter or if located there, on the DC fuse panel, are good, and see if you have 12v.
If not, confirm there is 120 into the converter by its circuit breaker on the AC panel and also by trying something else plugged into the receptacle the converter is plugged into (if the converter is a plug in )
Photo in Profile
