Jul-31-2021 09:37 AM
Aug-08-2021 08:04 AM
eric1514 wrote:MrWizard wrote:Or I could put a switch on one of the two small leads running to the isolation solenoid as Pianotuna suggested. But either way, I would be losing the alternator's contribution to charging the house batteries while traveling and amps is amps.
Eric1514..Ok , I'm on page 5 of 7,
Find the heavy battery cable that goes from the Intellitec to the house batteries, find the most convenient spot in that cable run to cut it and in insert a 200 amp DC circuit breaker, the marine style have push button that opens the breaker contacts so it acts like a switch, and a lever reset that closes them, this will be manually operated by you the driver when travelling, these are very reliable and can removed or replaced easily if there is ever a need to do so
Aug-08-2021 07:03 AM
BFL13 wrote:I think I'll give up RVing and take up something simpler like rocket science.
This only happens when the batts are nearly full. If they are low when starting out, you can set the controller to 14.6 and unless they get nearly full while driving, no light. Unless there is still some sun or if gen is allowed on arrival that's as high as it gets that day.
You real problem is getting them full while driving when starting low. Your alternator charging will be lamed by the solar's higher voltage, but it has low amps. You need lots of amps to get them up before arrival at the next site.
Your best amps would be from gen charging with a high amp converter. But high amps gets you to Vabs sooner at a lower SOC so the light comes on, and stays on during the Absorption the rest of the way there.
You could isolate the engine batt, and go with a high amp converter off the gen with solar added by setting solar and converter to the same high voltage. With a DC-DC you could have three chargers adding their amps and no light.
Your only limit is the gen watts as to how big an amp converter it can run, and to have the converter voltage adjustable. So toss the PD unless it is as high amp as the gen can run, and get an adjusatble voltage PowerMax LK model with as high amps as the gen can do. Set it to 14.6, the solar to 14.6, and any Dc-Dc to 14.6.
Note that a PowerMax 75 amper pulls 1700VA set to 14.6v doing 75 amps on a low battery. If your built -in gen is one of those non-inverter types it will likely not run as high an amp converter as an inverter-gen of the same |"watts" (acting more like it is MSW -it is not but it acts in a similar way for this exercise), so it can get tricky picking how big an amp converter you can run. The PowerMax 100 amper is PF corrected so it can be run by almost the same inverter-gen as the 75 amper which is not PF corrected. A Honda 2200 portable does 1800VA but my B&S 2200 does 1700VA. Gotta watch out when running things to the max you can get away with.
Of course it is no good having a converter with too high an amps that you can't run it at home on an extension cord, but only off your RV gen. BTDT. Have to have a lower amp portable charger to do the RV at home. Keeps you busy making sure you are using the right charger for where you are.
Or just accept a lower amp charging rate while driving and get by somehow with however full the batts get on arrival.
Aug-08-2021 07:00 AM
Aug-08-2021 03:42 AM
Aug-07-2021 07:18 PM
eric1514 wrote:BFL13 wrote:Yup. That's looking more and more like the plan. I'm not sure 14.4 won't light the lamp. That's the next test. I learned today 14.2, won't.
So set the controller to LFP 14.4 and head down the road. When you get there, you can do whatever works as required.
Aug-07-2021 06:03 PM
wguss wrote:You might be right.
I ran into that exact situation on our last trip out earlier this year. I haven't changed my solar system for years but for the first time my battery light came on when I started the engine. I had the rig plugged in all night so the batteries were topped off and didn't require much charging. I glanced at the volt meter and it was pushing 15 volts! I turned off the engine then thought to look at the voltage coming out of the solar controller and it was 15 volts. I disconnected the current coming from the solar controller and restarted the engine, no light.
I shut down the engine, re-connected the solar and waited a few minutes and the voltage from the controller dropped to 14.6 volts. (What's recommended for my AGMS) I re-started the engine (2005 Ford F-53 chassis with V-10) the light stayed off. My first thought was that the controller will equalize the batteries automatically once a month and that was the cause of the high voltage coming out of the controller so I am going with that, but I could be all wet!
Aug-07-2021 05:59 PM
Aug-07-2021 05:57 PM
Aug-07-2021 05:40 PM
Aug-07-2021 05:22 PM
BFL13 wrote:When I started the RV, the voltage at the starter battery dropped from 14.3v to 14.25v. What I meant was that if I was more patient, I could have idled the engine until the PD brought it up to 14.4v to see if 14.4 would set off the light. I've seen 14.4v at the starter battery on the monitor but not with the MH engine running at the same time. The highest I got today was around 14.25v at the starter battery with both the converter and the alternator running. The current was about 6 amps.
I think you have it backwards. If you idled for a while the alternator voltage would taper to 13.8ish. meanwhile the PD set to 14.4 might eventually get the batts to near that. with voltage drop on the PD wiring you might never see 14.4 at the battery even with the low amps at the high SOC meaning almost no voltage drop.
Solar's low amps means little voltage drop unless thin wiring, so you could set that to 14.5 and get 14.4 which might ot set off the light.
You have to test for how high you can set the solar without the light coming on when the house batts are full. If they are full you don't need to be doing that at all, so if you did have a way to turn off the solar when the house is full while driving, you could get to the campground with the house full, no red light, and alternator charging looking after the starter batt.
BTW, do you have the charge wizard or pendant to make the PD do 14.4? If not, it will only do 13.6. What are you doing with that for testing?
Aug-07-2021 04:50 PM
pianotuna wrote:
That will work for the alternator--but the six volt batteries may prefer 14.8 from time to time. (once a week?)
Aug-07-2021 04:46 PM
eric1514 wrote:
First test.
I ran the batteries down a bit and then plugged in the coach to shore. I have a PD converter and I let it bring the batteries back. When the starter battery was at 14.3v started the engine. That brought the voltage down to about 14.25. I couldn’t get the voltage back up. I suppose if I idled for a while I might have been able to raise it. The current was at about 6 amps. The dash alternator light didn’t come on.
It’s still too hot here to uncover the RV, so I was using the converter/charger to simulate the solar panels. What I think I learned is that the PCM is tolerant of voltage above 14.2. So right now I think if I change the profile in the controller so that it never goes above 14.2v I should not see a light.
Aug-07-2021 02:58 PM
Aug-07-2021 01:03 PM
