Final report—maybe. Warning—long!
The Titan BrakeRite EHB was installed last Thursday. It is definitely smoother in its operation (than the Dexter actuator was). Voltage check in the driveway confirms why. The Titan starts running with as little as 1 volt on the control line. So it starts pumping on light braking from the truck, and then ramps on up. Also, the Titan is a 1500 psi actuator compared to 1600 from the Dexter. That allowed me to change the gain on the truck controller from 6.0 to 7.0 without wheel lockup. That in turn will cause the truck controller to output just a little more voltage on light braking getting the actuator turned on just a bit sooner and smoother. Despite the lack of the aggressiveness setting in my truck, it seems like the Titan turns on at a low enough voltage that it may be fine with the Ford IBC eliminating the need for an after market controller. We start a trip soon, and we’ll see how it feels after some miles.
Issues along the way:
It seemed like everyone (and his brother) recommended using the Titan Ford/Chevy adapter with the adage that it wouldn’t hurt if you don’t need it, and it may help. In addition, Titan documentation seems to indicate that it is needed on Fords after 2006 ½. So, the adapter arrived, and I installed it on Saturday. Next time I tried the truck IBC, it threw a wiring fault. When I checked the adapter, it measured less than .2 ohms regardless of the polarity of the meter. That’s a short circuit, so out it came. Not wanting to start a long trip with any chance of problems, I bought 2 drum brake magnets and wired them in. The actuator cranks up fine at this point—road test tomorrow.
A second issue is that the Titan makes noise and clicks about every 3 seconds. This is, no doubt, the Ford IBC pinging the trailer to see if it is still connected. The noise changed and got quieter after I installed the magnets. In fact, it is currently so quiet that some folks might not notice it on their trailers. However, it concerns me that it will put premature wear on the actuator. At the time I discovered this, I wondered if a properly functioning adapter would have drained off enough current flow from the ping to stop the actuator from clicking. Further research will be needed including getting specs from Titan engineering, and getting a scope on the brake control line to measure the ping (don’t have a scope yet.) However, see additional information in the paragraph below.
Rant:
On three prior occasions, I spoke with a fellow (name omitted to protect the ??) at Titan Customer Service and Warranty. This fella was unable to answer any tough questions like “how can I test the Ford/Chevy adapter to confirm that it is defective?” He wanted to blame the actuator noise on a defective Ford IBC (just put in a P3 and everything will be fine). Today this guy left work early—lucky me. And, I was referred to another person (Randy) who was very knowledgeable. This individual confirmed that the adapter was defective. In addition, he stated that the small noise from the actuator would be no problem. He also stated that a properly functioning Ford/Chevy adapter would have drained off the current from the ping, and thus the actuator wouldn’t be clicking.
