i'm PRE-neophyte all i have been doing is reading, watching videos, looking at wiring drawings (no hands on)
it seems everything i have seen regarding large scale
goes to 'cell groups', cells in parallel packs, or cells in series packs
treated as one larger cell
for 12v, 3-4 cells arranged series depending on chemistry, and parallel the needed number of packs needed for the 'pack size'
some use individual BMS units on each 12v group wired to each cell
it is charged with a 14.x charger, not with a 5v charger
some parallel a number of cells then series them for 12v ? bank voltage
the BMS goes to each group of parallel cells, but not too each individual cell
they also use a 14.x bank charger not 5v
i have not seen anything using a 5v charger running to BMS or cells
to charge a bank wired for higher output voltage 12, 24v, etc
i saw a video discussion on tesla batteries
the cells were connected with 'fuse wire' to a buss bars
no individual BMS per cell
buss bars arranged the cells in large parallel packs that are series
for high voltage
if a cell goes bad, takes too much charge power or too much output
it takes out the fuse and that single cell goes off line
these parallel packs are very large so loosing a few cells will not cause a noticeable affect on performance
loose to many and you a 'alert' regarding battery capacity and service
there is a BMS of some sort, but i 'think' it deals with each large parallel group as one large cell
BMS is concerned with cell group voltage and total power out or total input needed , which indicates too many 'individual' cells are offline
I can explain it to you.
1997 F53 Bounder 36s
