does anyone know how to remove this box section?
anon125
It looks like it is riveted together!
thanks all
7 REPLIES 7
anon125
what is all that square section for?
thanks all
MFL
Nomad II
Nomad II
Dewalt makes a nice rivet gun, with a swivel head. It makes working in tight quarters a little easier.
Jerry
DougE
HomeDepot has all you need with this.
Currently Between RVs
DrewE
It's also reasonable to reassemble using machine screws and nuts rather than pop rivets if you prefer to do that. Getting wrench on the nut may be a bit tricky for some of them. (You probably could also get away with sheet metal screws in this case, being careful not to have them near anything that oughtn't get stabbed by their pointy end.)
MDKMDK
You can pick up a pop rivet tool at most big box and hardware stores. They're easy to use.
https://www.google.com/search?source=hp&ei=11nsXPv8K4HcswXv3IyABA&q=pop+rivet+tool&oq=pop+rivet&gs_l...
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
anon125
is a pop rivet 'gun' available at hardware stores?
thanks
DougE
Drill out the center of the pop rivits with a 1/8" drill bit, then insert new pop rivits when you're through.
