@#$%^& onan starter
MrWizard
Moderator
Moderator
Marquis 5000, mpdel BGMFxxxxxx
starter spins and rattles does not engage, it worked at lunch
anyway i need the correct part number so i can pick one out of the myriad of online sales offers
will probably order from Amazon so i can get it soon as possible
and install
this just had to happen on a Friday of a holiday weekend
AWE $HxT .. dang it
downloaded the PDF of service manual, NO part number for stater
currently looking online for parts list and part number
I can explain it to you.
1997 F53 Bounder 36s
6 REPLIES 6
MrWizard
Moderator
Moderator
sorry slow follow up
starter is in, and generator is running fine
still need to take a couple pictures of that splash guard/flange
to help clarify what i posted
bounder39zman
hopefully you get correct part with that part number. that is old, superceded number. current Onan part number is 191-2416.
Good luck with that repair. The older Onan Marquis series generators were great units, imho.
MrWizard
Moderator
Moderator
did some exploring and dissamebly today
the back side 'splash plate' ?
is just a flange that can be removed to give access to the starter and fuel pump
3 screws hold it to the bottom of the RV
4 bolts (2) on each end, hold it to 'pan' holding the Onan
it was not easy getting a socket or wrench on the inside to hold the bolt head
while i undid the 1/2 nut on the outside
but the flange out of the way access to the starter is much better
will have it running again by Sunday afternoon
sorry NO pictures, very dirty hands and no one to be my photographer
MrWizard
Moderator
Moderator
found it on amazon $56 be here on Tuesday
nothing is going to get here any faster, some are cheaper both amazon and ebay
but won't get here until the the 31st or later
edit;
getting it delivered to an amazon locker nearby, be here on Sunday the 26th
MrWizard
Moderator
Moderator
thank you
Dutch_12078
The Onan part no. is 191โ€“2158.
Onan BGM Parts Manual
(Page 21)
Dutch
2001 GBM Landau 34' Class A
