Dometic AC and heat
GDMoser
Good afternoon. I was looking at a friends TT that has an issue with the AC coming on when heat is being called for. In the past only the heat would come on but this year it is turning on the AC fan. It is I believe a 4 button Dometic thermostat. What would cause this? I know some units turn on the AC fan to circulate but he claims it never did this before this year. Is there a factory reset or a way to not turn on the fan? I have not found the manual for this unit yet as I only had a few minutes to look at it and will investigate further this weekend.
Thank you.
Gary
2 REPLIES 2
GDMoser
Thank you for the response. I will look at this tomorrow.
Gary
dougrainer
He has to set the FAN mode to AUTO. If set to LO or HI, the AC fan comes on when furnace is called for. Doug
