Dometic RM1350 leaking glue from freezer
Byrogie
Latest issue with this fridge. Upper right quadrant of freezer leaking some sort of glue?
Sticky, no odor, affecting door seal.
Extended warranty guy tells tech to prove itโ€™s coming from the fridge. Duh!
https://www.dropbox.com/scl/fi/c350thr6blpjvabrb6pz1/IMG_0430.HEIC?rlkey=22ktixzkamw5om4roxfbd8qma&dl=0
2 REPLIES 2
Byrogie
Apparently I need a computer to insert a picture. Iโ€™ll repost once I find one.
stickdog
Would glue be leaking?
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
