dometic rooftop Air conditioner
mooreboys
My ac compressor will not stay running long enough to cool unit. we replaced the control box, and thermostat. that didnt work, so we replaced the whole unit with a new ac! still happening with new unit. it seems to be getting hot, and popping the breaker.the compressor runs for a minute then shuts down.
4 REPLIES 4
dougrainer
You have replaced the COMPLETE system and still have the same problem. The problem HAS to be 120 voltage supply problem. Doug
copeland343
Low voltage = High amps. Check all connections on A/C power and breaker panels, That is were I would start.
memgrove
I have read on the forums that one other owner had problems similar to what you are describing. He figured out the cold air was blowing directly on the thermostat and shutting the ac down for a while and then back on for just a minute... Might be worth a shot for you to test yours.
Mike
2006 Chevy 2500 4X4 crew cab Gasser
2013 Dutchmen Denali 311 BHS (Love the trailer HATE the manufacture!)
1492
Moderator
Moderator
Moved from Forum Technical Support
