I bought some last summer on eBay , when I was having AC issues and the AC guy that came out had supply chain issues cause he has to order from a factory-authorized place . So I just bought them myself and I wanna say they were pretty cheap like 12$ for one and maybe 18 or so for the other ( run and start ) see the follow link for the price and ones I bought, keep in mind this was for my AC your will probably be different :click here
You can also use a 60 and a 5. Amrad? was the best brand before I retired but also priceyโฆ American made and guaranteed for life. I only carried 440 v caps โฆ that held up a little better in the Az. Desert . Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed. 2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes WILL ROGERS NEVER MET JOE BIDEN!
IF you can read the specs go to an "electrical motor" shop (You can google them) and they will either have a replacement or be able to get one..
I do agree 60 bucks is a bit pricy.
Home was where I park it. but alas the. 2005 Damon Intruder 377 Alas declared a total loss after a semi "nicked" it. Still have the radios Kenwood TS-2000, ICOM ID-5100, ID-51A+2, ID-880 REF030C most times
Go to capcon capacitors and pull up the list of oil filled capacitors and then look in the 370 volt list. About the 5th or 6th from the bottom on that list you will find the 60. It appears you can save a fair amount. No reason to buy more than one.
As jkwilson said same number capacitor will work. Brand not important. Capacitors normally store a charge (if yours was smoking maybe not) but make sure you de-energize just in case. Arc between two posts.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ Ayn Rand
