Duo-Therm Thermostat Conversion
RichPal
I've read the numerous posts about the Duo-Therm thermostat conversion to a Hunter 42999 digital thermostat. I followed one post where I added a separate switch to the bottom of the Hunter base. This is for the Hi-Lo fan function. I attached one end to the 'G' terminal on the terminal board of the Hunter. The other to go to the Blue wire. Now there are 6 wires on my Duo-Therm. R, G, Y, B, W, Brn. Orange is not used.
The Hunter has 6 terminals, 1=0, 2=G, 3=W, 4=Y, 5=Rh, 6=Rc. Rh and Rc are jumper-ed. Now comes my problem. I got so confused between the different posts I don't know which wire should go where.
Places To Go, Things To Do, People To See
3 REPLIES 3
1492
Moderator
Moderator
Moved from Forum Technical Support
donn0128
Download and print the instructions and follow them. On my setup I did have to reverse two wires, but worked perfectly.
BTW you posted this in the wrong forum. I have notified the moderator to move it for you.
