Jun-07-2019 04:39 AM
Nov-03-2019 03:29 PM
wa8yxm wrote:Why does a 29 have 100 AH but only 20-25 usable (20 percent) and two GC-2s have 220 AH with 100-115 usable (50 percent)?
As for the size of the batteries. That is a function of total watts stored. (amp hours times volts)
Some numbers In all cases I'm talkin 12 volt battery packs
Group 24 about 75 AH
Group 27/29 just shy/over 100 AH
Group 31 About 120-130
GC-2 pairs (Two 6 volt) 220 Amp hours
So each six volt battery is between a 29 and a 31 in weight and total volume..
Plus they are a bit taller so you don't need to water as often
And yes 1 12 volt (likely a 29) to a pair of GC-2 gets you from about 20-25 usable amp; hours to 100-115 That's a SERIOUS upgrade.
Nov-03-2019 01:29 PM
Nov-03-2019 11:44 AM
Nov-03-2019 08:39 AM
hedgehopper wrote:Utility power or sweat it out.NRALIFR wrote:Then how do you run the AC?
I personally don’t like the idea of depending on a generator to run the AC, because that typically means you’re going to need a bigger generator, and you’ll want to run it a lot more than for charging a battery, and at a higher load on the generator, so it will be making more noise and consuming more fuel.
Nov-03-2019 08:31 AM
Nov-03-2019 07:53 AM
Jun-26-2019 01:12 PM
Harvey51 wrote:
We never plug in to shore power even at home except battery charging once or twice in winter. No generator. We camp only in Canada, usually fairly far north where air conditioning is not necessary. Some charging from the engine while driving. I tried a single 100 watt solar panel flat on the roof first to see what it could do. I was very pleasantly surprised that it fulfilled all our electricity needs. Since installing the solar panel about 5 years ago I have never seen the batteries below 80% charge. Now we don’t worry about electricity at all - water is the limiting factor in our boondocking. We were just out for a full week in campsites without electricity with the battery monitor indicating 100% all the time. The freshwater tank and two jugs of drinking water just made the week. We use propane for the fridge and making tea or coffee on the stove.
Jun-24-2019 05:22 PM
Jun-22-2019 03:03 PM
Jun-22-2019 07:34 AM
wa8yxm wrote:
I will deal with the size issue.
Many posts the person says "I have a 12 volt battery".. great. I'm looking at a 12 volt battery as I type. I can hold it in one hand comfortably 7 Amp hours capacity.
I once borrowed a battery from a battery company for a weekend This sucker was a good 4 feet long. 3 or more high and a foot thick. they loaded it on my rented trailer with a fork lift. another of the same powered the fork lift.. About a thousand amp hours.
See what "I have a 12 volt battery" is not enough information.. both are 12 volt batteries.
Jun-09-2019 04:45 AM
SoonerWing03 wrote:
For this trip I doubt we will need the AC but if I am going to purchase a generator I might as well get one big enough to run the AC in the event that we want to go off the grid in lower elevations. Going off grid just opens up sooooo many more opportunities and is really at the essence of what I want our family camping experiences to be. However my wife is more of a "glamper" so I will have to meet her in the middle.
We like our coffee in the morning and the kids will want to be able to charge their phones at night. We would probably watch 1 maybe 2 tv's for an hour or two in the evening and may play a movie on 1 of them requiring a DVD player. If the phones have much of a signal at al, they will opt for playing around on them rather than the TV once the sun goes down. 1 or 2 lights max would be all we need and they are already LED's.
Jun-08-2019 10:22 PM
Jun-08-2019 06:17 PM
mordecai81 wrote:
I have a Champion 3000w generator that will run the AC and a stand alone 60 amp Boondocker charger that I plug into the generator and then use jumper cables to attach to the battery posts. It charges the battery as efficiently as is possible via a generator. We also have roof and portable solar that is either very helpful or not at all depending on weather and shade. If you charge only with the built in converter/charger, NPS campgrounds don't have long enough generator hours to get the batts fully charged.
Jun-08-2019 06:25 AM
