Front tires on the truck
ceasare
Came back from our 10,000 mile trip cross country again. Went to rotate the tires and get an alignment, and the front tires had sone scupping. They only have 30000 miles on LT tires. Could it be from towing the 5 wheel?
9 REPLIES 9
bikendan
Could be bad shocks.
2oldman
Cummins12V98 wrote:
What air pressure are you running in the fronts? What tire size and load range?
I'm not the op.
Cummins12V98
2oldman wrote:
2019 Chevy 2500HD gas 2017 jayco Eagle HT 28.5
Do you know your loaded and un loaded axle weights?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
2oldman
wa8yxm
More likely an alignment issue. But follow the link someone posted from Google.
Old-Biscuit
I typically get 60,000 miles before new tires (thread still good I'm just anal about tires)
Tow a 14K 5th wheel.....7 yrs was FT
NO front tires wearing out in short mileage has nothing to do with towing 5vr
What truck do you have....year/brand/model etc?
What tire pressures are you running...front & rear----towing/non-towing??
Suspension, ball joints, shocks, weight on front tires/air pressures etc
corvettekent
Mine do that too, so I always rotate them every 5,000 miles. I always thought it was from my off road driving in FWD.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Xflyhighx
Iโ€™m very interested
2019 Cedar Creek Champagne 38EL
TrailAir Pin Box
Hensley TS3 trailer saver
2017 Laramie Longhorn 4x4 dually
14' Porta-bote
Honda 3000is or 2 Honda 2000โ€™s
Life is good in the good old USA
