Furrion TV DirecTv remote codes
Learjet
Took a while to figure this out, since the Furrion TVs are not listed anywhere.
DirecTv remote codes:
39" Furrion works with code 10054
29" and 24" Furrion...code 10056
*UPDATE*
Just got the codes for my Genie RC73 remote for the Furrion TVs above.
For the Furrion 39" use JBL as the TV, then select I don't know my model, it will try code 1 of 1
For the Furrion 29" or smaller use Concerto as the mode and select I don't know my model, it will try code 1 of 1.
Hope this helps someone :W
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
6 REPLIES 6
Learjet
B&W Ram Companion
Wildcat_323rbx
To program Furrion TV remote codes for universal remotes use the LG TV codes
Wildcat_323rbx
Clay L wrote:
I haven't checked this out because you have to register with the Furion forum to download the pdf with Dish and DirectTV remote codes, but if you need a Dish remote code it might be worth a look.
***Link Removed***
The official answer to the Furrion universal remote codes is to use the LG Codes they are the same
gosha44
Some how I lost the remote for Furrion Tv , bought a cheap RCA remote at Walmart tried code for Emerson TV brand code 10178 worked . Cheap fix for this trip .
Clay_L
Furion remote codes PDF
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
2oldman
Most of us find that regular old LCDs hold up to travel pretty well.
