Mar-03-2018 01:07 PM
Mar-06-2018 08:26 PM
landyacht318 wrote:
Which charger did you use on the 2 amp setting?
My friend has a 2/10 amp schumacher that on the 2 amp setting will not go above 13.7v, and was at less than 0.62 amps on a battery I knew was nowhere near fully charged.
Irritated, I put my meanwell power supply on this battery set it at 14.7v and the battery was taking over 16 amps less than a minute after taking it off the 2/10 amp schumacher, and the ~100Ah battery wound up accepting 33 more AH, according to the attmeter on my Meanwell output, before amps tapered to a low enough level where they could be considered fully charged.
Voltage fresh off the charger is basically meaningless, unless it instantly drops to 12v or below, indicating a shorted cell.
Do not trust any charger to do what it says it will do. Verify. With an Ammeter in addition to a voltmeter.
Put somethng like this inbetween charger and battery. DO NOT trust any charger to do what it says it will do without verifying.
inline wattmeter
Most people with absolute faith in their whizz bang smart charger purchase will be extremely let down if they actually knew and understood what was NOT going on, which should.
Mar-06-2018 06:26 PM
Mar-06-2018 06:12 PM
Mar-05-2018 10:06 AM
Mar-05-2018 09:29 AM
Mar-05-2018 07:54 AM
2oldman wrote:landyacht318 wrote:AGMs can run in any position.
I wonder about tellycomm AGM's, and whether they are actually OK to orient on their sides.
Mar-05-2018 07:35 AM
Mar-05-2018 07:32 AM
Mar-05-2018 05:34 AM
Seem like in dedicated telecom usage, there would be absolutely no reason to ever use them on their sides, and perhaps they are not designed to be tolerant of long term being on their sides, subject to road and engine vibrations.
Mar-05-2018 01:02 AM
Mar-04-2018 06:03 PM
Mar-04-2018 05:34 PM
BFL13 wrote:
Depends on the individual RV's layout/floor-plan for being able to do this, but I have a mix of AGMs and Floodeds. Key is that the AGMs can be inside the rig, but not the Floodeds. I split the batteries into two different banks.
The AGMs in a bank just do the big inverter, which does "whole house" for all 120v items I run (not the air conditioner, fridge, and WH of course) so that takes care of a big bunch of 12v.
The "normal" RV 12v stuff (furnace, lights, fans, etc ) are run from the Flooded bank as a separate event.
I keep track of how far down each bank is getting and recharge as necessary using the charging specs for the AGMs on them, and the charging specs on the Floodeds for them. I have an adjustable voltage charger so that is no problem. (PowerMax ADJ type)
In addition I have two separate solar arrays on the roof, and each has its own controller, which has the right charging specs for each type of bank.
At home, I keep each bank at its own Float voltage with two different chargers for that.
What I really like about all that, is the regular 12v Flooded batts can be run down farther so I don't have to care about getting too close to where the inverter will alarm off when I run the microwave or whatever. The inverter having its own battery bank means freedom compared with before when I had it on the same bank with everything else 12v.
Mar-04-2018 04:45 PM
beemerphile1 wrote:Vintage465 wrote:
This is a pic of the data on the battery.
Just pointing out, deep cycle batteries in RV use generally the ah rating is at 20 hours. The rating on the label is at 8 hours. Apples and oranges.
Mar-04-2018 04:10 PM
