Generac generator
CARBONE
Hi All
Have a Generac PP-50, ran fine up to a few days ago, it will crank but wont start, It will if i give it a short of starting fluid and runs ok
any help for an old bloke
Thanks
AL
5 REPLIES 5
Pass42
In Albany, NY there is an excellent generator tech.......expert in Generac as well as others....Paul Reed518-449-0716. He has fixed my generac with ease and efficiency.......
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
BTPO1
Sounds like it is not getting gas soon enough. Mine has a priming switch at the local control you are supposed to hold for 10 seconds before starting, you hear the pump pumping gas to the generator. From the remote station it usually takes about the same amount of time to start. Could also be the choke not working correctly, which would make it harder to start. Mine was sticking and hard to start until I found the problem and fixed it. I have the Generac 5.5kW unit
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
tenbear
Mine has always started but sometimes it takes a lot of cranking. I believe the gas in the line to the genny runs back into the tank. Maybe the shot of starting fluid get the genny running and is more effective at getting the gas to the generator.
2010 Subaru Impreza Sedan
1492
Moderator
Moderator
Moved from Forum Technical Support
old_guy
this is going to be a question I did answered also. a friend of mine said he went out to the garage to exercise his genny and it would only start running after he gave it a shot of starting fluid. at first he thought the carb was gummed up but he always runs it until it runs out of gas in the carb, so we ruled that out, thought it might be the spark plug but it runs OK once you use the starting fluid so we ruled that out. only thing we can figure is the cold is doing it. some motors are just ones that hate to start once it gets cold out.
