โMay-15-2023 01:20 PM
โMay-16-2023 04:06 PM
โMay-16-2023 03:15 PM
โMay-16-2023 02:39 PM
Boon Docker wrote:swimmer_spe wrote:bikendan wrote:swimmer_spe wrote:jjrbus wrote:o
I find the dB ratings to be misleading, not useless. Some sounds within a rating can be more annoying. Then "quiet" generator is relative, A quiet Honda generator is quiet compared to an open frame construction generator. But hardly quiet.
What I speak of is that.... You can carry on a conversation around the Honda ones.Good luck doing that to a Champion.
Which Champion generator are you referring to? Open frame contractor-style or inverter generator?
Nearly every owner of a Champion inverter generator, that I've seen post on various RV forums, loves their Champion.
The open frame ones. Here in Canada, I have yet to see any other style for them.
Have a look here - Champion Inverter Generators - Canada
โMay-16-2023 02:36 PM
โMay-16-2023 01:45 PM
โMay-16-2023 01:38 PM
bikendan wrote:swimmer_spe wrote:Boon Docker wrote:swimmer_spe wrote:jjrbus wrote:
That's funny and doubtful.
Honda 2000 - 57db
Champion 2000- 53 db
How can the Honda be quieter with a higher db rating?
I have never seen any of the quiet Champion ones.
Then you need to, before passing judgement.
โMay-16-2023 12:55 PM
Honda 2000 - 57db
โMay-16-2023 12:53 PM
wing_zealot wrote:
I'd also like to mention, that i thought dB measurenments for portable generators was always at 7 meters, at 1/4 load. That's the only dB ratings i ever recall seeing.
โMay-16-2023 12:19 PM
swimmer_spe wrote:wing_zealot wrote:
I don't know what you mean by "Honda Quiet". Since Honda doesn't make a 3500 W generator, there is nothing to compare it to. So how many dB's do you consider to be "Honda Quiet"?
Secondly, are you looking for 3500 W surge or continuous?
At least for me, It's hard to be helpful when the parameters seem to be rather vague.
What I want is 30A available at all times. That is the rating of my trailer. So, as I understand that works out to be about 3500-3800W
Even at full load, the smaller 3000W ones seem to be quiet in comparison to most others.
โMay-16-2023 12:08 PM
โMay-16-2023 11:56 AM
โMay-16-2023 11:54 AM
Honda 2000 - 57db
โMay-16-2023 11:31 AM
Honda 2000 - 57db
Honda @ rated load is 57, 1/4 load is 53. Champion only claims 53, probably 1/4 load but don't give @ rated load db.
โMay-16-2023 10:12 AM
Honda 2000 - 57db
