Generator exhaust pipe location on Jayco Toy Haulers
La_Gasser
Why did Jayco engineers figure the best place for the generator exhaust pipe to end would be to locate it directly in front of the storage door which has the Universal Docking Station inside and your stored items? If you are running the generator while setting up or breaking camp, all the heat and fumes are directed at you. Has anyone modified this exhaust point? Seems like extending the pipe another 18" or so would get it away from this area and not effect anything else. Thanks
2 REPLIES 2
TEXAS
Because they are idiots. Generator exhaust. Should never come out. Next to or under any window are door of any kind.
eHoefler
When I installed our generator, I went with oversized pipe and all the way to the back of the trailer, out the right corner. Then I install a GenTuri to get it above the roof line.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
