getting the fridge ready for a trip
anon125
we have to have the fridge and freezer working before we go.
how long does it take to be fully cold?
does it take much propane?
is 2/3rds full still the normal 'full' for propane - maybe to allow for expansion.
it is 3 years since we RVed - so we are a little rusty!
thanks all
2006 Itasca sunova 29R
14 REPLIES 14
JiminDenver
We have a procedure that lets us use the fridge within a short time of turning it on. In your case I would at least let the fridge run long enough to see that it is functional before doing it. Within a hour or so the freezer will start to cool and you will be able to jump start it.
We keep frozen gallon and half gallon jugs in the bottom of the freezer. I may find out today the the work for the week is moved and we can go camping. I'll take a charged battery and the jugs to the camper, get it running and put the jugs in the freezer and fridge. Then I'll go to the grocery for food and by the time I get back the jugs have cooled the fridge to the point that the food can go in and it will act like a cooler until the mechanics catch up.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
anon125
thanks all
time2roll
anon125 wrote:
there is no power where the MH is stored.
thanks all
When did you last check the batteries?
Battery is priority one. The fridge is easy.
atreis
Overnight has always worked for me - start it in the evening and it's cold the following morning.
I recommend getting at least a small solar panel in order to keep the charge on your battery up so that it's ready to go.
2021 Four Winds 26B on Chevy 4500
old_guy
on thing they, the pros tell us, is to make sure the food and drinks you put in the frig are cold. this helps the frig maintain it's coolness.
bigfootford
Nomad II
Nomad II
wolfe10 wrote:
Yup, the refrigerator PC board, ignitor and propane solenoid are all 12 VDC powered. Should be off the house battery bank.
So OP should make sure his battery is in good shape and fully charged..
Make sure all unnecessary 12vdc items are OFF.
Fridge and safety devices, propane, CO etc will pull about .5 amps when the fridge is cooling.
Once the fridge is cooled down figure on .2 amps..
.5 amps an hour = 12ah for a full day of initial cool down.
Jim
2000 2500 9.6 Bigfoot,94 F250, Vision 19.5, Bilstein shocks, air bags/pump, EU2000, PD 9260, Two Redodo 100ah Mini's, Aims 2500 Conv/Inv, 200W. solar, Morningstar Sunsaver 15A/ display panel, Delorme/laptop for travel, Wave-3 heat.
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
2oldman
thanks all
Your batteries must be in working order.
pianotuna
Nomad III
Nomad III
Hi,
It will burn very little propane but will take six hours before it starts to cycle on and off.
Bring freezer "bricks" with you and place 3 in the freezer and one in the fridge. That tends to "jump start" the cooling process.
Be sure the RV is level.
Regards, Don
anon125
thanks all
bigfootford
Nomad II
Nomad II
I use shore power to do the initial cool down and leave it on that mode until we are ready to go. I do make it run on propane for an hour or so to make sure that function works! No surprises when you are firing up the truck, ready to go.
I always run the hot water tank and furnace too for a bit just to make sure they operate.
I Keep a gallon ziplock bag full of ice cubes in the house freezer.
I put it in the freezer compartment of the rv's fridge... That helps a lot. Also put 5-6 cans of soda pop or beer in the tray below the cooling fins of the fridge compartment.
This get's the fridge cool quite quick....
I do not know how long it takes. I always start the fridge up on the day before leaving.
As for how long a 40# tank will last.
Our fridges take about 1000btus/hr when cooling..
If the fridge is in the process of cooling down it will use about 24,000 btu's (24 hrs).
There is about 92,000 btu's in a gallon of Propane.
Easy math eh? Rounding you can figure the initial cool down will take about 1/3 gallon.
A 40# tank holds about 4 gallons. Depends on the fella filling...
After the fridge has cooled down the big variable will be the outside temperature.
At around 100deg I think the fridge is in cooling mode almost 100%... So 1 gallon every 3 days...
At around 70 deg maybe it runs a little less than 1/2 of the time... You do the math.
Jim
wolfe10
Unless ambient temperatures are below 50 degrees, I would start it 24 hours before you want it cold.
And, if it has been three years since you have used it, you need to do a complete propane system check and a refrigerator "burner area tune-up".
Brett Wolfe
Ex: 1997 Safari 35'
sch911
I start it up in the evening, then load it the following morning. Doesn't take much gas at all. If you have shore power hooked up it'll take no gas...
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
2oldman
4 hours, no, I don't know
