โJul-08-2014 01:56 PM
โJul-09-2014 09:50 PM
โJul-09-2014 09:29 PM
JiminDenver wrote:
I may still get a TS-MPPT-45 but until we know what is happening with the trailer,everything is on hold.
โJul-09-2014 06:51 PM
mena661 wrote:JiminDenver wrote:Is that using the EcoW?
I wanted to mention that there is a person on you tube by the name of icurnet that successfully uses two 150w 12v panels in series. He has a bunch of videos including time lapsed days where he exceeds 20a at times.
โJul-09-2014 06:49 PM
โJul-09-2014 06:34 PM
โJul-09-2014 06:14 PM
โJul-09-2014 05:50 PM
โJul-09-2014 04:11 PM
12thgenusa wrote:
Refresh my memory. How are you obtaining the PWM amperage for comparison on the 24-volt panel.
โJul-09-2014 03:17 PM
โJul-09-2014 01:36 PM
โJul-09-2014 01:16 PM
MrWizard wrote:
If the panels get so hot the voltage is low, the MPPT should be passing the amps straight thru
โJul-09-2014 10:43 AM
BFL13 wrote:Yes.
I haven't measured comparable voltage drops Spring/Now, but does wire resistance go up if the wire is hotter?
โJul-09-2014 09:56 AM
โJul-09-2014 08:55 AM
