โDec-18-2018 05:57 AM
โJan-07-2019 05:15 PM
Wild Card wrote:motc777 wrote:Wild Card wrote:
The 12v come from your ac unit through the thermostat to the furnace
That's the thing. I hear in the ceiling the clicking when I turn on the heat on the wall thermostat. Just the furnace is not kicking on.
If you dont have 12vdc between the 2 blue wires at the furnace then you need to check it at the stat. At the stat but not at furnace a wire got broke. If you have it at the furnace than there is a bad board or bad connection.
โJan-07-2019 01:05 PM
โJan-07-2019 11:54 AM
โJan-07-2019 10:08 AM
โJan-07-2019 05:52 AM
dougrainer wrote:
There is a Black reset/circuit breaker button on the furnace case. I will bet you turned it OFF when doing your work. Doug
https://www.bing.com/images/search?view=detailV2&id=93A6DAF3B6DF306C35354CAD91371417ED927777&thid=OI...
โJan-07-2019 05:31 AM
โJan-06-2019 06:46 PM
โDec-19-2018 04:15 PM
โDec-19-2018 05:46 AM
โDec-19-2018 04:10 AM
motc777 wrote:dougrainer wrote:
Smell LP and hear Ignitor. Only thing to do is to pull the furnace and clean the burner and check the burner for mud nests. NO OTHER diag is needed until you pull the furnace. Doug
OK. The furnace is under a couch that I can lift up. Do I totally have to remove it from propane lines, etc, or can I just take the top cover off?
โDec-18-2018 02:08 PM
โDec-18-2018 01:46 PM
โDec-18-2018 08:34 AM
โDec-18-2018 06:12 AM
