My blower motor went out and I installed a new one. Thought I was ready to go but an unrelated wire came loose and I wasn't sure where it went. Turns out they are all loose because the connectors have opened and are brittle. You can't tighten them because they break. Picture of the area is attached. I think I have a wiring diagram. I'll include that in a reply.
Electrical wiring isn't my thing. I know enough to get me in trouble and with a heat wave hitting tomorrow, I don't want to make a mistake here. Maybe you guys can walk me through this. Fist step I believe would be seeing if the diagram is correct and then figuring out where a couple of wires go.
Bill, Carol & Striker The Cat
2005 Everest 323k, Anderson gooseneck adapter
2007 Dodge Crew Cab, 5.9L, auto, drw, 4wd, 3.73 axle, B&W gooseneck hitch
