Hey Westend, lower watt A/C
JiminDenver
You recently asked me which A/C I use. Well come to find out it has been discontinued and the replacement is rated for 410 watts instead of 446 watt. It would run off of just two panels.
click
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
5 REPLIES 5
westend
Thanks, Jim. That little window shaker looks just the ticket of what I need.
As it is, the extra 2" of foam board I installed in the ceiling cavities does a great job. If I let natural or fan-aided night time circulation fill the trailer and close windows in the morning, the interior stays cool until well into the afternoon. This is when parked in full sun with daytime temps into the 90's.
Still, an additional panel and two more batteries will get me off-grid AC (for a period) and that would be a welcome addition when on the road.
'03 F-250 4x4 CC
MEXICOWANDERER
Or you can forget your wedding anniversary and get the cold-shoulder for weeks.
JiminDenver
I use a 1250fc Tripp-lite industrial inverter to start mine rated at 446w.
pianotuna
Nomad II
Nomad II
Gulf,
Probably a 1000 watt psw. But if you wanted to be sure a 1500 watt PSW.
Regards, Don
Gulfcoast
I understand it's 410 watts when running, but what size inverter would it take to start it? Starting watts could be double or triple the run watts when starting up.
RV'ing since 1960
Dodge Cummins Diesel
Mega Cab
Jayco Travel Trailer
