โOct-10-2019 10:50 AM
โOct-14-2019 05:50 AM
Since you ordered 2 hall effect ammeters, know that the instructions say each display is calibrated to the sensor it arrived with and not to mix them up.
โOct-11-2019 06:19 PM
โOct-11-2019 08:19 AM
Is there a PID for that available that an OBD2 reader could monitor? DashCommand is a great app for realtime monitoring hundreds of different sensors that the diagnostic and emmissions controllers use.
โOct-11-2019 08:12 AM
I got one of these hall effect ammeters on my dash reading current into or out of my battery:
https://www.amazon.com/bayite-Digital-Cu........rds=bayite+ammeter&qid=1570775614&sr=8-7
โOct-11-2019 07:57 AM
Digital panel meter under $10 with shunt on ebay. Need to custom mount.
DC-100V 10A 50A 100A Voltmeter Ammeter LED Dual Digital Volt Amp Meter
current in the motor will drop, ONLY if the hot pump has an open circuit
a hot pump 'Stall' with out open circuit, will Increase current drain
and the pump motor will get hotter
โOct-11-2019 02:18 AM
โOct-10-2019 11:50 PM
โOct-10-2019 11:26 PM
โOct-10-2019 10:03 PM
โOct-10-2019 08:07 PM
maillemaker wrote:
Note I do not want to use a Fluke meter or similar current meter - I want a permanent gauge-driving setup.
โOct-10-2019 06:59 PM
You could install a Hobbs switch to a small led light, but not cheap $80 bucks my last one. Imo probably liquid fuel in till over engine, then liquid into vapor because of engine heat. So your pump might be working good, but fuel vaporizes before getting to where the fuel needs to be liquid at ie injected into cylindar.
Just you or is this common problem with your make and model.
Yes. In fact, after I replaced the tank pump (low-pressure), we had the problem again, and a shop replaced the high pressure pump on the frame rail below the driver's door because they said it was running a little low. They subsequently tested all the pressures, and they were fine.
I kept a FP gauge attached to the Schrader valve on the fuel rail during one trip after that. It ran at the correct pressure (I think it was 50 psi, but that was a couple of months ago, so that may not be exact); however, as soon as I climbed a long hill in heat over 85 degrees F, the pressure dropped to zero and stayed that way through multiple attempts to restart. When I pressed the release valve on the gauge, I got nothing more than a few spurts and drips of fuel; I was halfway expecting to get a high-pressure burst of boiled fuel, but got nothing like that.
After about 45 minutes, though, I was able to start it just fine, the pressure went immediately back up to 50, and we were on our way again. That happened three or four times in one trip, and it was always the same: a drop to zero FP in a hot climb, a 45-minute wait, and a no-problem start with FP at specs until the next big climb. It has never happened except when very hot, and then only when climbing long hills. No engine overheat, though.
โOct-10-2019 03:36 PM
โOct-10-2019 02:13 PM
maillemaker wrote:Most any indicator will do the same. Basically not a warning so much as an indicator of why the engine stopped.What would a light telling you the pump is on or off accomplish?
It would tell me whether my loss of fuel pressure is due to vapor lock or pump failure.
My CEL does not come on until the engine dies.
Steve
โOct-10-2019 01:45 PM
