HR 03 Neptune front brake pads
Stude55Dog
I am in No Fla and need new disc brake pads for the front of my Neptune. I am told the Bendick # MKD 786A pad set is discontinued. Anyone have info on replacement pads to these or who to call. Thanks
5 REPLIES 5
j-d
Are you planning to do a brake pad replacement yourself? If you can safely get jacked, supported and wheel/pads off, take a set to NAPA and mention the part numbers in your post ^^^. I'd be very surprised if you don't walk out with either a set of pads or confidence you can order them in as MKD 786A from somebody like Amazon.
Sounds like a great coach, by the way! Our first RV was a Holiday Rambler Class C and it was WAAAY better built than this late model stuff.
Stude55Dog
I am in the Keystone Heights area in No Fla. The following are specs
Model 34PDD HR NEPTUNE
YEAR 05/2003
CHASSIS ROADMASTER
GVWR 24,000
It is a Wesport axle. Original part number for brake pads was I am told, Bosch 143687-0187 and 0188 which are now discontinued like supposedly the Bendix MKD 786A. Thanks for the info.
j-d
Now I'd really like to know what your Chassis is. This is the RockAuto reverse lookup for mkd786a pads:
FORD F-650 (2004 - 2008)
FORD F-750 (2004 - 2008)
FORD F53 (2008 - 2011)
FREIGHTLINER M2 106 (2004 - 2011)
FREIGHTLINER MT35 (2004 - 2009)
FREIGHTLINER MT45 (2004 - 2009)
FREIGHTLINER MT55 (2004 - 2009)
INTERNATIONAL 3000 (1999 - 2002)
INTERNATIONAL 4700 (2000 - 2003)
Alternate/OEM Part Number(s): 4153301, 4153346L, 4C4Z2001NA, X4153301FTL
j-d
Amazon Link
j-d
Discontinued, no replacement available sounds like nonsense.
What is the Make, Year, Model, GVWR and Tire Size of your Chassis? Not the Model year that Holiday assigned to the Neptune, but the Chassis that's under it.
Often a veteran parts person at NAPA can figure stuff out that the kid at O'Reilly cannot. Try a personal visit to a NAPA store at a non-peak time of the day.
Where are you in North Florida? For how long?
