Oct-10-2021 04:46 PM
Nov-12-2021 11:01 PM
Oct-14-2021 07:19 PM
albow wrote:trailrider wrote:Well, that didn't work. It sure gripped but I couldn't turn it. I'm going to get my stronger neighbor to give it a go and then try something else. I wonder if it's because it's nylon and the sprinkler heads are maybe pvc?
Go to the hardware store and buy a "sprinkler riser removal tool." I have removed several with one of these, works perfect.
https://www.homedepot.com/p/1-2-in-and-3-4-in-Plastic-Nipple-Extractor-26076/100203404
Oct-14-2021 05:18 PM
Oct-14-2021 05:07 PM
Oct-14-2021 03:08 PM
Oct-12-2021 06:24 AM
Oct-11-2021 04:29 PM
Oct-11-2021 11:58 AM
Oct-11-2021 07:06 AM
Oct-11-2021 06:57 AM
Oct-11-2021 04:01 AM
Oct-11-2021 04:00 AM
#1Flyboy wrote:Essentially what I did with the drill. I had plenty of traction. Enough to break my file.
If the remaining threads are of plastic or nylon, you could heat up a screwdriver head & melt a grove/ slot in the material. Then cool down the screwdriver head & unscrew the remainder…A picture of your problem would be helpful….
Oct-11-2021 03:58 AM
DancinCampers wrote:Not enough to grab even if I made a piece loose like you suggest. Thanks
I had one break off on my previous coach. I used a pocket knife to lift up an edge, then needle nose pliers to twist it out.
Oct-11-2021 03:56 AM
trailrider wrote:Thanks. I'll give it a shot.
