I think I'm looking at new batteries.
joshuajim
I have a pair of interstate Costco 6v that are about 3 years old. We don't boondocks anymore and the trailer is at the ranch and hooked up constantly. PD9855 (?) does the charging.
I did a SOC and all 6 cells are 1.275 or slightly higher. I checked the voltage on the positive (connection) battery and it is about a half a volt higher than the negative (connection) battery.
When I put the Meanwell on the positive battery bubbles like crazy and the negative battery barely bubbles.
I reversed the battery and the negative battery still does not bubble much. I cleaned all the connections and the interconnect cable reads 0 ohms.
I'm pretty sure it means new batteries.
RVing since 1995.
23 REPLIES 23
joshuajim
Final report - I put the batteries back in and turned off the disconnect. After 3 days they are still at 12.7. All is well.
RVing since 1995.
joshuajim
MEXICOWANDERER wrote:
No do them separately and use a hydrometer, to verify the weak sister cells. Ideally, each 2-volt cell would be available. That ended when the over-the-top tartop batteries disappeared.
The equalization Must be current controlled. 5 amps per 100 amps amp hour capacity or 5%.
MEX, you have mentioned using the 100w bulb to control amperage many times, but how are you actually measuring the amperage.
RVing since 1995.
MEXICOWANDERER
wopachop
My friend has a trailer with (2) 6v costco batteries. They are around 4 years old. Never seen an equalization charge.
Ive asked many times to mess around with them and get shut down. Lets say one day im allowed to do the MEX 16v equalization charge like you taught me in a different thread.
If i do charge them together at 16v and notice one battery bubbling stronger than the other, is it best to charge them individually? Since i have the ability to do so?
MEXICOWANDERER
Jim now that you resolved your own issues (Involved using intelligence I may add):)
This is the missing link in your diagnostics...
It's fast, inexpensive and impossible to fool. It may show a bad battery and will declare it needs further investigation is needed with a hydrometer. Equalize, or end up as a bad battery depending on the hydrometer results.
For those of you who deem the sixty bucks, the purchase price will screw up your weekend beer budget...keep up the poor guesswork you'll need it for gasoline or replacing good batteries with good batteries.
I sneaked in an unrelated quip. I hope you focused on it. Then I posted this latest remark praying some of you can follow the dots
MEXICOWANDERER
incomplete
MEXICOWANDERER
Maybe this sense different become clear more...
Cheap price battery is harder to care for. Die soonest. Use more electricity to maintain. Problem with OP resolved. Maybe good time to change gears?
whiteeye42
Wanna Shock?
Connect a three-cell battery to a three-cell Rolls battery of the lightest weight. Then perform a charge efficiency factor verification test at the beginning and after 50 full 50% discharge cycling series. SURRRRR-PRIZE! The Rolls charges faster and easier. Connect parallel 3 or 4 budget 3 cells in parallel then to the single Rolls. Even more shocking. And the ROLLS is far more forgiving.
Cheap batteries are unforgiving -- they will screw you into the ground. There is MORE difference between a T-105 and a Rolls battery than between a Trojan and a cheapo warehouse three cell battery.
Never try it but offer tons of advice is a loser. For totally different reasons its like comparing a Lifeline to a Chinese AGM. The charge efficiency factor difference comes at a shock to most people.
What is this it does not make sense ?????
Me,Wife two boys and two dogs
2008 Dodge Ram Quad Cab 4x4 DRW 6.7 cummins
2008 Jayco Eagle 341 RLQS 37' with B&W turnover ball & companion hitch
using rotochoks
add state map
MEXICOWANDERER
Wanna Shock?
time2roll
wopachop wrote:
I'm not far from you if you ever want to equalize the 6v's individuality. But reading this morn is sounds like everything is ok.
I think the primary concern of the OP was during an equalization (Meanwell) the amount of gassing was somewhat different in the two batteries.
I see no issues.
theoldwizard1
Lwiddis wrote:
Hooked up constantly bothers me. I keep my batteries on a light duty solar system with a controller. Three years isnโ€™t exceptional.
CONCUR !
I always recommend that when lead acid batteries are store for more than a few weeks, that the charger be connected via a mechanical lamp timer set to allow about 2-4 hours of charging per day.
wopachop
BFL13
Good news.
My 6s were 1.3 SG as new baseline. Was info a few years ago that this was the new normal for 6s. For temperate climes--SG should be a bit lower in the Tropics ISTR.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
joshuajim
time2roll wrote:
9855 sounds like WFCO not the far better PD.
Let them sit disconnected and see if voltage holds up 12.65+ for a few days.
I would continue to use them until they develop other issues.
Memory is the second thing to go! I looked it up and itโ€™s a PD9260C.
RVing since 1995.
