The slide will not come in or go out in my 2000 fleetwood Terry, model 275J. I have replaced the controller, in hopes that was the problem since the original one showed only 10 volts going to the motor even though over 13 volts was coming in to the controller. I removed the motor this morning and hooked it directly to the battery. Grounded the motor to the negative side of the battery and used a jumper wire to the red and black wires of the motor.(separately, not at same time) I get no movement whatsoever from the motor. I get 13 volts from the jumper wire and the motor housing. I did this test with the brake engaged and disengaged. Do y'all agree that my motor is shot? Any suggestion of further testing is appreciated.
P.S. The motor is a Power Gear 520576.
2011 Fun Finder by Cruiser RV, model X210WBS
2017 Ram, 1500, Tradesman,
10,000 Equal-I-zer hitch
