โNov-06-2014 06:57 AM
โNov-06-2014 10:20 AM
โNov-06-2014 09:53 AM
Bobbo wrote:
Buy a Circuit Tracer. Put a Socket to Outlet Adaptor in the light socket. Plug in the tester's transmitter. Take the detector to the breaker box and it will show you EXACTLY which breaker is powering that circuit. I use mine all the time.
And I second RJsfishin's suggestion.
โNov-06-2014 09:41 AM
RJsfishin wrote:
I'd start w/ getting a new voltage detector,...could have kilt you !!
โNov-06-2014 07:56 AM
wa8yxm wrote:
If your voltage detector found no voltage, but the wires arced. FAULTY VOLTAGE DETECTOR.
Can not comment on the GFCI
Wire Trackers (harbor freight sells one) may assist you in tracing the problem down.
โNov-06-2014 07:54 AM
โNov-06-2014 07:31 AM
BFL13 wrote:
"I have thought of turning all breakers off except one and using that breaker to back feed the light fixture to see if it returned power to a breaker that has no power. Any ideas?"
Usually, you turn the branch CBs all off first and then turn them back on one at a time till the power comes back on at that location.
โNov-06-2014 07:22 AM
NinerBikes wrote:
I'd say you either need a new voltage detector, or a new operator.
Something is not right. Even when not hot, you never let 2 wires touch each other, put a twist cap on on all the hot wires, neutral too, when working on them.
โNov-06-2014 07:20 AM
โNov-06-2014 07:13 AM
โNov-06-2014 07:12 AM
โNov-06-2014 07:09 AM
โNov-06-2014 07:08 AM
โNov-06-2014 07:03 AM
