โApr-21-2018 12:24 PM
โApr-22-2018 06:56 AM
DiskDoctr wrote:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29545741/gotomsg/29545774.cfm#29545774
โApr-22-2018 06:18 AM
DiskDoctr wrote:
I'm guessing the "you need a bigger inverter" suggestion means they were using the built in transfer switch in the inverter?
I had the same issue last year when deciding what and how to wire in an inverter. The recommendation I liked most and followed from the folks here was to add a standalone ATS (Automatic Transfer Switch) to the shore power/inverter circuits to keep the charger, inverter, AC power all powered only when necessary without chance of backfeed, double feed, or conversion loop (battery to AC while AC charging battery)
Then I was able to use whatever inverter size I wanted and use it to power EVERY outlet and AC item in the camper- up to my available inverter amps.
Works perfectly!
โApr-22-2018 06:17 AM
MrWizard wrote:
is your shore cord in or near the same basement location ?
yes ?
then step (1) is turn off the circuit breaker for your charge converter
step (2) put fridge on LP, put water heater on LP
step (3) use what ever adapter is needed and plug your shore cord into the inverter
turn on inverter
reverse process when you need the generator
BEFORE you start the generator
โApr-22-2018 06:16 AM
โApr-22-2018 05:27 AM
โApr-21-2018 07:57 PM
โApr-21-2018 07:21 PM
โApr-21-2018 07:18 PM
2oldman wrote:2001400ex wrote:You can if you just plug your shore cord in like I said earlier.
I was expecting to be able to plug into any outlet and use them after the install like they come from the factory.
โApr-21-2018 05:32 PM
โApr-21-2018 05:11 PM
โApr-21-2018 04:53 PM
โApr-21-2018 04:33 PM
โApr-21-2018 04:29 PM
time2roll wrote:jcpainter wrote:2/0 would be tight depending on length. I recommend 4/0 for 2000 watts.
They used #6 wire and it should have been #00.
Custom cable here:
http://www.genuinedealz.com/custom-cables?size=48
โApr-21-2018 04:24 PM
time2roll wrote:
How is the inverter wired? How many batteries? What size 12v wire?
Does it just sit there and you have to plug in the main cord?
Otherwise you need to pull wire and install a transfer switch and remote if you want push button power.
Ok to post some pictures.
BTW my 300 watt inverter powers the outlets just fine. Dealer is full of it or does not understand electricity.
โApr-21-2018 04:21 PM
Hope you mean 3000 watt not 300. a 300 watt inverter might power a laptop, not much else... Sort of like the Op with a 2000 amp inverter If he has that he must have a portable power generation plant.:E
