Is AC fan speed on auto adjustable?
Freightguy
Can the fan speed be changed to always run on high when the fan mode is set to auto?
2009 American Tradition 42P
2011 Jeep Wrangler Unlimted
9 REPLIES 9
Freightguy
I have;
Coleman Mach 8 15K AC unit x 3
Dometic Control Kit # 3312020
Dometic Wall Thermostat # 3314082.011
dougrainer
Freightguy wrote:
This is the situation I wish to have.
valhalla360 wrote:
Ours has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
With the always on, even when the thermostat turns off the compressor, the fan keeps going.
Then we need to know model of the AC(Brand also) and what type wall tstat you have now. Doug
Freightguy
valhalla360 wrote:
Ours has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
valhalla360
Nomad III
Nomad III
Ours has 4 options:
- Hi Always on
- Low Always on
- Low Auto
- Hi Auto
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dougrainer
Simple answer--Maybe. If you want HI fan continous, then you have to use Hi Fan/Cool. List your system and wall tstat. Some systems, the Fan will always run on either Hi or Lo(selected speed by user) in cool mode and shuts both the Fan and Compressor off when temp is reached. Some will cycle thru the Fan speeds (hi/med/Lo or Hi/lo) when on Auto cool. It depends on the system. Doug
wildtoad
Might also want to make sure filters and coils are clean.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
time2roll
Check your freeze sensors first. They should be positioned right in where the ice is forming. Access by removing the interior trim. Either way the condensate will flow off the roof unless you have some type of other drain that is plugged.
You may need to post exactly what thermostat brand and model you have. The Dometic units should be switching the high fan when the interior is 4+ degrees higher than the set point.
theoldwizard1
A/C icing is usually an indication of low refrigerant.
