Is it ok to travel with a full plastic gas can on my bumper?
Naio
It doesn't seem safe but what else would I do? I haven't used my genny enough yet to know when I will need gas.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
61 REPLIES 61
mlts22
My two centavos on this:
I cannot -stand- the EPA approved cans. I have encountered one type of spout that requires twisting... and leaks. The only type of spout I've found which is decent is the one where you rest one notch on what you are filling, press down on a wedge, and it unlocks to pour.
The other twist-to-pour spout, I learned to my horror that it is to be avoided. I went to relieve pressure before filling up my generator, opened it... and out went almost a half-gallon of gas... in a fine mist, just like I was holding an oversized fuel injector Luckily, there wasn't anything around that could have been a point of ignition, or I would have had a pretty nifty crater, and a trip to the local burn ward.
Since I use a pickup truck, I place my gas cans in a row, then use a ratchet strap through the handles to make sure they keep in a straight line. This way, if something rams my vehicle, the cans will remain in place.
Once I move to a motorhome... different story. I am most likely going to see about a hitch mounted cargo carrier that is mounted on a secondary receiver bracket with a rise, higher than normal, then store my portable generator and my gas cans on that. This way, there is a good chance that the rear-ending vehicle goes under the rack, as opposed to striking my gas cans directly.
Another idea I may do is (assuming the motorhome's structure allows this) is to mount pack mounts for RotoPax containers on the rear wall of the MH. If I can mount two rows of paired brackets, I can carry 5-20 extra gallons of gasoline for a generator, as well as the generator itself right below on a hitch cargo rack.
Don't forget what truck camper people do. There are some very excellent front bumper and hitch mounted carriers which can carry a generator, and 2-4 cans of fuel for it in the front. I've yet to hear about a mushroom cloud caused by this setup, and it does work well.
NinerBikes
Naio wrote:
I don't see any mention of concern about gas,say, splashing onto the tailpipe. Is that a thing?
The bumper is deep, but the only realistic place to put the can is above the part of the bumper that is nearest the tailpipe.
have you ever run your generator out of gas yet?
Maybe this is a non issue, take your generator with you to go get some gas when you go grocery shopping, at the same time?
Naio
Salvo
It gets easier (and safer) than that.
Look at the gen manual and see how long it runs on a tank. In all probability, the OP will be moving to another camp long before the gen tank is empty. Fill it while underway again.
I drive about 10k miles per year and fill the gen tank about twice a year. Why carry spare fuel for the genny?
The OP's rig is probably overweight already. Why add more weight?
ol Bombero-JC wrote:
Way too easy..:W..:B..:B
ol_Bombero-JC
Bumpyroad wrote:
PatrickA51 wrote:
. I would stop and fill a gas can if I carried one before I got to my camp site.
sounds like a plan to me
bumpy
Tin_Pusher
I LOVE my MFC's ๐Ÿ™‚
Tin Pusher's Guide To Successful RV'ing: "Don't get mad, don't get in a hurry"
2002 1500HD
2002 Wilderness 265H
1997 Seadoo GTI
1952 Wife;)
austinjenna
From the link: "* Note: Federal law prohibits the use of this container for the storage of fuel."
Interesting, eh? It's that CARB CR*P again
Yes they need to put this on the site so that they are able to sell them legally. Actually when I bought mine I think it had a sticker on it for potable water only LOL. I just was tired of the crappy CARB ones they have now leaking all over, nothing coming out, standing there for 10 minutes trying to get 5 gallons in my truck blah blah blah. All I know now is with these cans I can empty 5 gallons in my truck in 30 seconds without spilling a drop.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
NinerBikes
Reddog1 wrote:
Everyone thinking the US military and NATO do not know how to store and transport gasoline? I have to say, I am really shaking my head on this subject.
Does their gas have ethanol in it, or is it straight gasoline?
Reddog1
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
fj12ryder
I thought I read somewhere that the new metal gas cans, the good ones anyway, are zinc coated on the inside to lessen the worry about rust.
Howard and Peggy
"Don't Panic"
NRALIFR
NinerBikes wrote:
They had to switch to plastic when they added ethanol alcohol to fuel. It's hygroscopic fuel now, sucking moisture out of the humidity from the air, and rusting out steel fuel tanks.
I used this on my 5L Jerry can before I ever put gasoline in it. The 20L cans are used, and would be difficult to clean well enough to use it on them. If I was buying new cans, I would definitely coat them before filling them.
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
NinerBikes
Reddog1
Think maybe the US Military and NATO do not know about the issue with steel tanks? Personally, I have had far more issues with plastic tanks.
Wayne
Toad: 91 Zuke
RJsfishin
They went to plastic for more than 1 reason.
On a long trip, if the metal can touch anything metal, it can wear a hole thru the side in less miles than you would ever believe.
Another reason is rust !!!! I wouldn't have any kind of crappy metal can ever again.
Ever see a metal boat tank wear right thru the bottom of a boat ?? I have, not to mention the rusty stains where the tank slid off the pc of carpet that was supposed to stay under it. I'll take the carb **** over the metal **** anyday.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
