Jam nut size for e450 simulators?
slamac56
I have a e450 chassis under a 3010 sunseeker. can anyone tell me the size of the Jam nut to hold down the rear simulators on the lug nut extenders? Or somewhere I can buy them?
8 REPLIES 8
slamac56
Thanks I'll call on Monday, yes lock tite a good idea, just came loose and lost one.
path1
If you strike out....
Call this guy Arlin 1 800 420 5872. He is dist for Pacific Dualies. That is his cell number. He's a work-a-holic and at that number most of time. If he doesn't now he'll direct you to right person. Knowing what type you have would be big help.
I'm looking at a new set next to my desk as I type this post. Going to put them on when I finish with front end brakes. I also remember he said extra were $8.00 each.
Looked over all my paperwork and nothing size specific only model numbers on my directions.
I was wondering if I should put a little mid strength lock tite on, you answered that question for me. Or did you lose bolt around house or misplace it?
(I'm going from the Dicor snap on type to pacific dualies (bolt on type) because snap type decided to "snap" off on freeway. Those were Dicor "fastliner" that left me going 60 mph.
Another place is http://www.autoamenity.com/Wheel-Simulators/Ford-Dual-Wheel-Simulator.htm they are really order takers and refer you to Phoenix Wheel for questions anything other than what is your credit card number type thing. But they do have some info on there site that might help with size.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
slamac56
who would I call with this part number?
newman_fulltime
part numaber is a pnf98lnt
slamac56
Correct, this is not a lug nut, it is to hold the simulator on a lug nut extender, the simulator is jammed between the lug nut extender and this jam nut. It measures roughly 1" wrench size and the thread opening is .789 of an inch, measuring with my harbor freight calipers. Fastenal told me it was an automotive thread pitch but so far I have not found an auto parts store to help.
Tom_M1
That's a standard lug nut. What the OP is looking for is the nut that holds the wheel covers on.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
j-d
I'm gonna go with 9/16" diameter and 18 treads per inch, per this lookup at O'Reilly:
Dormanยฎ AutoGradeโ„ข - Wheel Lug Nut
Part Number: 611-127
Line: DOR
1 year limited warranty
โ€ข UPC: 19495111276
โ€ขWheel Nut
Multiple Applications
โ€ขBlack Oxide - Steel
- Thread Size: 9/16-18
โ€ขFlanged Nut - Black Oxide
- Steel
โ€ขWheel Nut 9/16-18 Flanged Flat Face - 7/8 In. Hex, 1-1/16 In. Length
โ€ขSold Individually
โ€ขHex Size: 7/8 Inch
โ€ขThread Size: 9/16-18 Inch
โ€ขType: Flanged
โ€ขSeat Style: Flange
โ€ขStyle: Flanged
โ€ขThread Handing: Right Hand Thread
and Picture:
The 7/8" hex size is one of the four offered on my NAPA-brand cross-rim lug wrench. But not common enough for Harbor Fright to sell in their individual $4 English or Metric (23-mm) deep impact sockets. I was able to order a single one from Amazon, but $8.
The Jam Nuts for Dicor, as MOD noted above, would therefore be 9/16-18. THAT nut is 1-1/8, by the way. But if you have an extra piece in there, like your OP seems to say, we'd need more info to try to help with that.
96Bounder30E
If they are Dicor brand......check here.....
http://dicorproducts.com/catalog/wheel-products/
Moved from DIY to Tech issues
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
