Key Ring
vic46
I am sure everybody enjoys those wonderful little loyalty program key ring tags as much as I USED to! I no longer have those little mutts on my key ring. They are in my smartphone.
Follow the yellow brick road below. This software will put the bar code from the tag on your phone and a photo of the tag on the reverse side of the bar code.
I also added library card, birth certificate, SIN card and drivers license in the card file.
http://www.keyringapp.com/
Have a great Christmas season all.
Vic, Brenda and the 10# killer Schtizu, Odie.
[COLOR=]Never argue with an idiot. You will be dragged down to their level and then beaten with experience.
4 REPLIES 4
fj12ryder
At least the person who finds/steals your phone will have all the necessary information so they can return it. 🙂
Howard and Peggy
"Don't Panic"
wa8yxm
Been using KEY RING for some time.. NOTE: Generally the phone's display will not scan on the flat scanner, IT may "Wand" if you are lucky...
But of course most places you can manually enter the number, or just feed it your telephone.. I've done that too. With computers networked a lot of info cross references.
Nice app though.
Now playing with windows 8.1... Oh the joy of a totally different operating system messed up even farther by a computer manufacturer.. I'm taming it.
Cat_Lady
To heck with the app…can I have Odie?
Cat Lady
As you slide down the banister of life, may the splinters never point the wrong way.
I_am_still_wayn
That will be very helpful for the identity thieves if (or when) you loose your smart phone. They thank you.
