keystone 'hideout' vs cougar??
scottmac
Hello, curious as the difference in these two models?, I like the cougar24rks TT floorplan and looks like the hideout has the same floor plan.the used 'hideouts' seem to less expensive than the cougars for same year, etc-thank you
4 REPLIES 4
scottmac
thank you for the reply
fla-gypsy
Trim level and price only, otherwise they use the same basic components and are made on the same production lines. Fluff is the only difference
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
scottmac
thank you
DutchmenSport
I think the Cougar is a little higher end camper, but you'll find the appliances and hardware are probably identical.
You really can't tell what a specific camper is like until you've stepped inside of it. The contour of the ceiling, the color of the wall paper, the style of the cabinets can make a camper feel claustrophobic or as inviting as cool stream in the middle of the desert. Both floor plans may be identical, but the two campers are as different as night and day.
Best advise. Now that you've identified the two campers that interest you, go find them and physically take a look. You will have your answer .... and .... don't be surprised if you end up not liking either one!
