โJul-24-2014 12:49 PM
โDec-30-2014 03:58 PM
โDec-30-2014 02:20 PM
LScamper wrote:
RV Buzz wrote:
"I checked the voltage at the socket while the genny's running and it's 15.5 volts."
Why do you have 15.5V at the socket, bad convertor? Way to high and may be doing damage to LEDs and other RV electronics!
โDec-28-2014 07:22 PM
โDec-28-2014 04:53 PM
โDec-28-2014 04:29 PM
MEXICOWANDERER wrote:
If you can use flat plate 50 SMD lamps measuring 5X7 CM Buy In Coins dot.com has them for 3.25 US free shipping no tax. Five ACTUAL watts. 48 LEDs. These lamps make SUPER compartment and stowage area lighting. We are talking BRIGHT. Not thr same vendor as the one with pathetic aluminum wire leads.
โDec-28-2014 08:53 AM
โDec-28-2014 07:16 AM
โDec-28-2014 06:09 AM
โDec-28-2014 04:36 AM
โDec-26-2014 10:57 AM
โDec-26-2014 10:33 AM
โDec-26-2014 10:28 AM
โDec-26-2014 07:26 AM
โDec-26-2014 07:16 AM
ryanw821 wrote:
I have 48-LED panels from ebay in my RV lights, $20 for 10 of them, about same brightness SLIGHTLY whiter tint that incandescent, and just a fraction of the power draw. Color hasn't shifted on them at all, never even heard of that on a LED.
They aren't perfect at only $2 per light, I had to put new adhesive on them because the junk that came on them only stuck for like a week, but beyond that, they work great and are quite a value.
