โNov-26-2023 02:29 PM
We have a 2016, 25; Forest River Sabre 5th wheel. For the sake of this scenerio, let's say the truck and trailer is on perfectly level ground both front and side to side. Typically when attached to the truck the front of the trailer is approx. 4-5" higher than the rear. When we unhook, we have to raise the trailer an additional ~.1.5 - 2.5 inches. As we lower the front of the trailer to level it front to back, the passenger side "rises" ~.75" for every ~3-4" of downward travel at the front. We continually have to do math based on the unhitched height of the trailer and "unlevel" the trailer side to side so it becomes "level" once the front is brought down. On our last trip the front was almos 9" high as we were on a slope so the passenger side roses up ~1.5" once the front was level. Soometimes we have to rehood up the trailer and adjust the "unlevelness" a second tiime just tto get it level both ways. There doesn't seem to be any broken welds or issues that we've noticed. The landing gear seems to touch the ground at the same time and we've recently had the wheels aligned and new suspensiion hardware installed (problem existed before and after that work was done. Is this normal? Anyone else have this issue?
โDec-01-2023 10:08 AM
You never mentioned your pick-up truck. It sounds like you have a 4-wheel drive. Your trailer is rather short and would end up with your current situation.
โNov-29-2023 03:49 PM
Maybe hard to diagnose from your description, but it is possible that your front landing gear legs have become out of sync, meaning, one leg is higher/lower than the other. Really common for that to happen, and very easy to fix. To check, just measure from the frame down to the bottom of each leg (the powered leg, not the pinned portion) and hopefully they are equally set.
โNov-30-2023 08:22 AM
thanks, I will try that.
โNov-29-2023 01:48 PM
Is this an Autolevel system, or are you dealing with just front legs? Hydraulic, or electric?
โNov-30-2023 08:24 AM
It's a manual system, only front legs
โNov-30-2023 08:20 AM
Hi, it's a manual system, just front legs.
โNov-27-2023 08:13 AM
There are hitches made to raise the height of the ball. If it rides okay the only problem may be running the refrigerator while towing.
โNov-27-2023 12:06 PM
No ball. It's a fifth wheel. ๐
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โNov-27-2023 02:16 PM
Sorry. I missed that. Someone else will need to help here.
