โMar-12-2022 07:07 AM
โMar-14-2022 11:03 AM
โMar-14-2022 10:16 AM
โMar-14-2022 10:06 AM
CA Traveler wrote:mine does with blue tooth.
Tom/Barb From the Victron specs it does not have the ability to display amps.
โMar-14-2022 09:50 AM
CA Traveler wrote:
Tom/Barb From the Victron specs it does not have the ability to display amps. Did you determine the 20A from say a battery monitor? Then the Victron could be supplying 10A to house loads plus 20A to the battery or 30A on it's output. This is how charging systems work - amps supply house loads and what is left charges the battery.
Your 30A unit is spec'd for 30A output not input. I didn't read the manuals but wondering if it can be downgraded to 20A. The voltage can be adjusted and that could reduce the amps.
At 10% efficiency your unit would draw 33A on the input at 36A for 20%. However the unit can be wired (and should be) to sense the actual battery voltage (both batteries). That means that wiring losses are a factor and the input amps could be larger drawing more input amps but IF your wiring (size and length) is per Victrons specs then wiring losses would be limited.
Just trying to see if we can get a better understanding of your system.
โMar-14-2022 09:12 AM
CA Traveler wrote:
For Victron documents a MH is non isolated. The emergency start solenoid could still be used for starting.
โMar-14-2022 08:58 AM
โMar-14-2022 08:19 AM
CA Traveler wrote:
BFL13 For an isolated system both the + and - wires are sourced from the charger to the remote battery, no common ground. All RVs use a common ground and hence are non isolated.
โMar-14-2022 07:54 AM
โMar-14-2022 07:49 AM
โMar-14-2022 06:17 AM
โMar-14-2022 05:50 AM
Tom/Barb wrote:A 30a dc to dc charger producing only 20a of charge current indicates 1) a very inefficient dc to dc charger with only 66% conversion efficiency, 2) an installation experiencing excessive voltage drop due to undersized cabling or bad terminations, and/or 3) a 20a dc to dc charger that is improperly rated as a 30a charger.BFL13 wrote:Yes.Tom/Barb wrote:Do you still believe that ?
This is what we did, A 30amp DC to DC charger gives you the ability to charge the coach battery bank while running the coach engine.
This limits the engine alternator to 30 AMPs thus prevents overheating the engine alternator....
Hope the OP doesn't .
Our equipment is operating as it should, 2 years in, set IAW Victron's settings .
So why shouldn't I believe that?
Some folks wouldn't believe, even when the proof is in front of them.
โMar-13-2022 07:36 PM
โMar-13-2022 01:28 PM
โMar-13-2022 11:54 AM
Tom_M wrote:Any chance a measurement of the charging amps was noted? Please post if available.
I have had my Renogy 170ah lithium battery for 2 years and have had no issues with it hooked directly to the alternator.
โMar-13-2022 11:21 AM
