MagneTec series 6300A # 6332 32 a converter w/c Fan Question
bigkenobsd
Hello, Thank you in advance for your help. I have owned this 92 Toyota Itasca for about 6 months now and I do live in it. The normal procedure is to plug into the shoreline from the house every night when I park.Usually it takes about 20 minutes for the converter fan (MagneTec series 6300 a m# 6332 32 amp power converter w/ battery charger ) to kick on and the it runs for a few hours and turns off. The outside temperature has dropped lately and the charger seems to be working fine but the fan does not kick on. I guess my question is this. Is the fan temperature controlled or is it supposed to run continuously while the charger is is charging. Thanks again.
11 REPLIES 11
wa8yxm
bigkenobsd wrote:
Progressive Dynamics 4600
Now let me explain something...
When you have a Magnetek 6300,, Finding a downgrade is downright hard to do. Cause that's about as far down as you can get.
Replacing the guts with a Progressive Dynamics Intella-power 4600
Well, Finding a BETTER one is something I've been trying to do or nearly a decade,, have yet to find one.. You just went from the bottom of the list.. To the very top.
GOOD CHOICE!!!!!!!!!!
BFL13
That will work. 🙂 Don't forget the Charge Wizard is part of that when you want to use the CW.
I see Randy is saying there will soon be a 14.8v PD9200 to meet the latest battery specs.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
bigkenobsd
BFL13
Yes, but which "upgrade" did you get? How can we be Monday Morning Quarterbacks and tell you how you screwed up without knowing that? 🙂
Photo in Profile
bigkenobsd
Hello Friends, Received the new converter in a timely fashion from Best Converters. The swap went smooth and the new converter is working fine.The one Thing I would make sure you do is identify and label every wire you remove.If you have the means, take a series of photos of your wiring for reference later. Thanks so much for the input you were so right Randy is the man and the converter is a perfect swap.
bigkenobsd
Thanks for all the input. I just talked to Randy and ordered the 45 amp upgrade kit and a surge protector. I am pretty handy and will post a update when the job is finished.
wa8yxm
Fan is thermostatically controlled, it comes on when it gets hot, if the air surrounding the unit is cold enough, it will never get hot enough to fire up the fan.
Page 2:
Upgrade, on the list of converters where units like the Progressive Dynamics 9200 (or in your case 4600) and IOTA with IQ-4 and a host of others are at the top of the list
That magnetek 6300 comes in dead last.. UPGRADE the thing.
The 4600 replaces the ELECTRONICS in the magnetek so you keep the same distribution panel, way cheaper than replacing the entire thing.
Randy at Best Converters can provide help, the web site instructions.
tenbear
I agree. the Magnetek or Parallax converter is a very poor battery charger. It's output voltage of 3.8v is to low for fast charging and high enough to boil the water in the battery.
I replaced my OEM Magnetek/Parallax converter with a Progressive Dynamics converter. It senses the battery's state of charge and adjusts the output voltage accordingly for fast charging and long battery life.
2010 Subaru Impreza Sedan
ScottG
Keep in mind that your converter charges the battery at 3 amps - not the full output of the converter.
The standard failure mode of that converter is for the fan to die which allows a current limiting resistor and bridge rectifier to fail. When that happens the failed diodes cause a continuous drain on the battery.
You've caught it right before the catastrophic failure.
It's time to replace it with a good three stage converter like a Progressive Dynamics Inc (PDI).
I suggest you go to Bestconvertercom and check them out. Randy is very helpful and will steer you in the right direction. There's even directions on their site of how to swap out the converter.
bigkenobsd
Hello jrnymn7 , Thank you so much for the response.I found exactly what I needed to know.
jrnymn7
http://www.hayseed.net/~jpk5lad/RV%20Information/MagnaTek%20Pwr%20Converter/RV%20Binder1.pdf
According to the picture on page 9, the fan is thermostatically controlled.
