Maintaining batteries
Silas_Carpy
New to rving as of May this year so first time winterizing. If I understood everything I read, including owners manual, I can leave batteries in rv and connect to shore cord and inverter will maintain charge. I’ve had it hooked for about 3-4 weeks now. I’ve been monitoring the batteries and today the 12 volt chassis battery was at 11.55 volts and the 6 volt coach batteries were 5.85. Does this method not maintain charge. 2009 Fleetwood pulse on dodge/Mercedes’ sprinter. Thanks.
18 REPLIES 18
valhalla360
Nomad III
Nomad III
Yes, it should be fine.
Something is wrong with your system if you are running below 12v after being connected to the charger for weeks.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
CA_Traveler
First and immediate step is to get those batteries charged. Discharged batteries have a shorter life, maybe much shorter. Borrow a auto charger for each bank to start.
2014 Grand Cherokee Overland
Bob
KD4UPL
Being plugged in should keep them charged. Yours obviously is not. What brand and model of inverter/charger are we talking about?
BFL13
If an inverter/charger, make sure the charger is "enabled" and there is 120v to the rig such as to the MW
If a converter, make sure it has 120v input. On that,
A. be sure there is 120v to the RV--see if the MW is lit. If so,
B. check for 120v to the converter. If so,
C. check the converter's RP fuses, check the battery fuse (or DC CB if that)
D.snap off the converter's 120v CB and see if the 12v lights work from battery (they will be dim at the reported voltage, but should still work)--if they do the battery fuse is ok, so that leaves the RP fuses if there is 120v to the converter.
The engine battery needs its own maintenance charger--it does not get any from the converter or inverter/charger. Various ways to arrange that-Trickle Charge eg.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
