โDec-17-2013 02:44 PM
MEXICOWANDERER wrote:
Batteries should be separated after the charging protocol. Connect all batteries together and apply 1 nominal 14.2 charging volts and there is no way any of the batteries can detect it one battery or a hundred are online, or the chemistry of any of them. The only requirement made of a charging system is that it not under or overcharge the battery. Voltage requiments for flooded 5% antimony batteries and pure lead AGM is similar enough for multiple warhead work.
It's when the charging ceases that the problems arise.
So go ahead and use a smart solenoid to parallel charge the batteries. I have done this too many times to count.
โDec-20-2013 08:41 PM
โDec-20-2013 07:13 PM
โDec-20-2013 04:22 PM
โDec-20-2013 03:08 PM
โDec-20-2013 11:33 AM
โDec-19-2013 11:13 AM
Here's a tip to understand the reality of same type of battery has different chemical attributes according to its state of charge or age.
Fully charge all batteries
Wait 4 or 5 days, then measure the voltage potential of each battery
Take a hydrometer reading then reconcile it to voltage of each battery.
A tenth of a volt is significant, two tenths is worrysome when you are trying to balance batteries.
To amplify the test, apply 14.8 volts after fully charging the batteries. Note that the cells with the lowest gravity and lowest initial voltage boil first.
Cells that droop after charging, actually CONSUME power. Roaches check in but they don't check out, time. The worse the cell the hungrier they get. Some are the eqvt of a 20 watt load on the other cells in the bank.
โDec-18-2013 10:24 AM
MEXICOWANDERER wrote:Thanks for saying this as it explains some behavior I noticed when I had the broken wire (and even after I fixed the wire).
โDec-18-2013 09:16 AM
โDec-18-2013 08:52 AM
โDec-18-2013 07:26 AM
Pipeman wrote:
Quoting Mex "It's when the charging ceases that the problems arise." I get charge them together and then disconnect them from one another after charged!!!!
โDec-18-2013 07:20 AM
โDec-18-2013 07:08 AM
โDec-18-2013 07:03 AM
โDec-18-2013 07:01 AM
โDec-18-2013 06:54 AM
