โJan-11-2015 06:51 AM
โJan-20-2015 09:48 AM
JiminDenver wrote:
For each of us different conditions exist. Gear, expected temps, altitude and weather all play a part in what we choose. Formulas and theory don't always that those things into consideration. Only side by side testing in a unique situation will give a person the answer to what is best in their situation. Even that is hard to set up fairly.
โJan-20-2015 09:06 AM
JiminDenver wrote:
I often wake to 12.4 or 12.5v and even tracking the sun the controllers don't ramp up to peak amps without the coffee pot pulling down the voltage temporarily. Once that has happened they will stay at peak until absorb is hit.
So at 12.5v my MPPT system is wont go peak and at a voltage low enough to get it to do so the PWM is really at a disadvantage via losing watts.
โJan-20-2015 08:26 AM
mena661 wrote:MrWizard wrote:I'm certainly listening.
another reason..why i keep saying its about watts not amps (but i'm flogging a dead mule) nobody wants to listen to that one
โJan-20-2015 08:22 AM
โJan-20-2015 08:16 AM
โJan-20-2015 07:52 AM
โJan-20-2015 07:48 AM
The part in the reference that has PWM equal or almost equal to MPPT within that panel temperature range never has PWM doing more amps to the battery than you would get with MPPT. Yet at 25C ambient, and 51C panel with 230w I get more amps to the battery with the PWM 14.5 vs 13.5 amps.
โJan-20-2015 07:41 AM
Salvo wrote:
Did you notice that I said cell temperature? The irradiance for that test is 1000W/m^2. If you have 1 m^2 panel, about 800W goes to heat. Panel temperature rises substantially.JiminDenver wrote:
75c is 167f
Just where do you plan on camping?
โJan-20-2015 07:10 AM
pianotuna wrote:
Hi Salvo,
I'd love to see an analysis of Mppt vs Pwm at a vmp of 33 with a panel temperature of 75C. To make it a level playing field use 16.5 v for the pwm.
โJan-20-2015 07:00 AM
jrnymn7 wrote:
So, if series/parallel is not an option, which way is best, where partial shade is concerned; series or parallel?
Thanks.
โJan-20-2015 06:46 AM
JiminDenver wrote:
75c is 167f
โJan-20-2015 06:36 AM
โJan-20-2015 06:30 AM
โJan-20-2015 06:25 AM
โJan-20-2015 06:09 AM
pianotuna wrote:
Hi Salvo,
i.e. MPPT configuration series/parallel @ 33 vmp
and PWM configuration parallel @ 16.5 vmp.Salvo wrote:
Fig 14 pretty much sums up the differences. The RV crowd are for the most part fair weather campers. That means cell temperature is in the range 40 to 80C. In that range, for the most part, mppt gains are between 0 and 10% better than pwm. On average it could be about 5%. Nothing to crow about.
